- Thread Starter
- #21
Thanks for the tip.Obvious the encoder part of LDAC has become part of Android but not all manufacturers implement it.
A workaround is to use a USB-C adapter like the Fiio BT11.
It is a Bluetooth5.4 transmitter supporting
- SBC
- aptX/aptX LL/aptX Adaptive/ aptX Lossless/aptX HD
- LDAC
Could be something for those who, for example, have Sony headphones with LDAC but no LDAC codec in their mobile. For my part. Maybe, it wasn't that expensive, $50. I'm not really hellbent on having LDAC, but I am stubborn about getting it to work. Mostly out of curiosity. I will still use a cable when I listen to music, regardless of LDAC or not.
That Fiio BT11 seems small and handy. If it's easy to connect to a device, headphones for example, plus if it has good transmission power/strength, it could be something. Best to check what it works with before buying:
Portable High-Res Bluetooth Transmitter BT11
Guangzhou FiiO Electronics Technology Co., Ltd.
www.fiio.com
On Sony so try with same AVRCP (1.6) profile. Not even Sony switches it back to 24 bit from 32 so you still have to go to developer options to switch that but probably everyone can live with it at 32 bit (lower compression quality).
I haven't tested that exact setting. When I do, later today or tomorrow, I'll let you know the result. Thanks for the tip.
