Fozzie Bear
- Joined
- Feb 12, 2025
- Messages
- 3
- Likes
- 0
Hi I joined this forum to ascertain if anyone is aware of a bluetooth receiver that will connect a dumb bluetooth device to an amplifier.
Most bluetooth accessories such as speakers etc transmit a bluetooth network identifier. This is used to identify the correct device to connect to. Under most circumstances you need a device with an operating system such as a mobile phone, tablet or PC with software that can scan for and connect to the network identifier of bluetooth devices.
In my scenario I have a bluetooth boundary mic VEC CM-2000BT which is a dumb bluetooth device which merely transmits its ID. I also have a preamplifier which has bluetooth audio connection which also advertises its bluetooth ID. There is no way to connect the boundary mic to the preamplifier without some sort of intermediary device which has an interface to scan and connect to bluetooth devices.
There are hundreds if not thousands of bluetooth receivers and transmitter/receivers available, some with displays but none that I can find that imitate a phone or operating system to be able to connect to a bluetooth ID. I have even thought about using something like a raspberry pi pico device which can connect to the boundary mic but would not really know where to start.
Does anyone know of such a smart bluetooth receiver. It's likely to be a proprietary or niche product but there must be something out there somewhere.
Thanks in advance
Fozzie
Thanks in advance
Fozzie
