Belden ICONOCLAST XLR Cable Review
Rate this cable
    Votes: 152 53.9%
    Votes: 86 30.5%
    Votes: 21 7.4%
    Votes: 23 8.2%
Billy Budapest
This would be a worthwhile purchase for a group of individuals or an audio club for situations like this:
uwotm8
Enlist a friend to help out with an ABX test and it will soon disabuse you of this notion.
I actually don't see how "just asking a friend" can help. That requires immediate switching ---> some cable switching tool/commutator.
Maybe I'll do something better - record some music playing (same song ofc) with both cables and check in some audio editor(s) for difference, A minus B I mean.
Will buy better AQ for sure regardless for the results. But what I think I hear for now should be at least partially capturable.
Haters gonna hate;)
My personal experince means a lot more than "that SHOULD work because..." for me, so my excuses here.
As example, I'm owner of these two epic products:
Sonies were bought just for fun after that review, and oh man... well they have not the worst FR curve but they sound not just like a garbage cans but a garbage cans with an old dirty pillow on it. Epic trash. But a lot of people liked it because... why? Review sayes it's good? Where's ABX? LOL. My - obviously badly colorating and weird signature overall - KZ IEMs are such a hi-end compared to.
My opinion on Verum, at the same time, basically follows the review.
Billy Budapest
A friend could do the switching. With banana plugs, it should be pretty quick. You’d be blindfolded and the friend could use a random number generator to pick cables. Run 10-20 tests over the course of an hour or two.
Billy Budapest
I do not think you will get any measurement difference of consequence by doing a null test. What you “think you hear” can only be tested via an ABX comparison. Then you can see if what you “think you hear” can be reliably duplicated in a controlled testing situation. You’d have your AQ cable, the “grocery” cable you used before, and another cable or two.
uwotm8
No measurements, read again pls. Such A minus B is a simple operation and a basic option for many editos AFAIK.
Switching RCAs will require 15 to 30 seconds at least and overall I don't like a "DIY version" of ABX.
Blumlein 88
Did you miss the null testing done by Amir in the 1st post? Some of us have the same results from other cables including Audioquest.
uwotm8
It was a wire loop testing, not a speaker(s) playing and being recorded, right?
Seriously, that or, say, one speaker "listening test" - please:facepalm: Oh, sorry, I mean it's ok - same as Sony ZX110.
Blumlein 88
If the signal going to a speaker is the same the sound coming out if it will be the same. Otherwise some magic that defies physics is happening. You could ask to record the signal at the speaker input jacks.
As for null testing sound from a speaker with a microphone, you will find far too many interfering factors. You will not get a good null one recording to the next with nothing changed.
uwotm8
It's actually funny how measurephiles react if something goes not as planned - "wrong testing! repeat till it will prove what should be proven"
Same as audiofools with their JUST LISTEN YOU WILL HEAR!!!11
Good point and pre-applied damage control. Much appreciated:p
P.S. Will record late night in quiet room and will re-record if there happens some unexpected noise, I think it's enough for a quick redneck-grade test
Blumlein 88
Go ahead, but I've done what you are proposing. You definitely should do it. It can teach you something. One thing being how very small a difference can be and ruin a null. Which will then lead to a better understanding of what a truly deep null means.
uwotm8
Well I'll try my best not to shake the mic etc etc. I understand such difficulties.
Blumlein 88
The issue will be noise if everything else is taken care of. Noise that is random will differ between two recordings, and limit the possible null. If you have a room that is 35 db SPL it is rather quiet. If your test signal is 100 db SPL your null will be limited by that noise level.
