BD DT 990 pro 250/80 ohm and DAC & amp combo
BD DT 990 pro
Hi, i'm from Slovenia and i'm looking to buy BD DT pros. I would like to buy a 80 ohm version but i can't find them in Europe. If you cannot help me, please then tell me which DAC & amp combo should i buy for the 250 ohm ones ( the DAC & amp need to be under 150 euros). Thank you for your answer.
Fiio K5 Pro and Topping DX3 Pro would be the best DAC/Amps close to your price range, however, they are both a little bit over.
The 80 ohm version has been discontinued couple of years ago, so unless you settle for another model or the 35 ohm version (still available in europe) you could turn to the second hand market.
I have the DT990 Pro 250ohm version. The Focusrite Scarlett 2i2 is barely loud enough. I ended up buying a Geshelli Archel 2 Pro, and I run that behind a Topping D10 I still had laying around. Definitely loud enough for me. I'd probably pair that with a better DAC when I was buying new.
Go for the 250 Ohm version and look for a DAC amp that can reach about 100mW in 300 Ohm with the functionality you want.
@Berwhale 's recommendations are top notch in that price class and will drive it effortlessly.
