Lower distortion? There’s a blog post from
Benchmark that states the opposite is the case for headphone outputs, as you have twice the number of amplifiers driving half the impedance. They still recommend balanced for line-level, but their claim of “substantial performance improvements” is somewhat vague and frustrating.
Balanced connections certainly promise better SNR, but what length of cable do you need for this to become significant? Sure, problems with the mains wiring can cause ground loops in some installations, but in the absence of a specific problem like that, how much would the SNR improve over a single-ended connection?
The one circumstance I can think of in which it would make sense to use balanced by default would be running long cables from a DAC to powered speakers through ducts that also contain power and network cabling. But then most active speakers only have balanced inputs anyway.
I have no dog in this hunt, do what you want. I did not read Benchmark's blog. I took your question as a generic ask and not applied to a specific device. But if your argument is to convince people differential/balanced circuits do not matter in the home, my experience differs.
I have a couple of short posts on the subject:
Differential circuits:
https://www.audiosciencereview.com/...d-balanced-unbalanced-and-all-that-jazz.1352/
Ground loops:
https://www.audiosciencereview.com/forum/index.php?threads/ground-loops-101.7162/
Yes, using differential circuits provides lower distortion, in theory and in practice, but of course it depends upon implementation. My world is at frequencies well above audio but the circuits often have to work to DC, and differential operation does what I said IME. Like Ripley, believe it or not, or review the info on the Web or engineering texts. Note there are several "flavors" of balanced circuits in audio, and not all are fully-differential, so do not all provide the same level of benefit. Twice the amplifiers is not how all differential circuits work, but for those that do, noise is not usually correlated so you get twice the signal swing but noise only increases by a factor of sqrt(2) and thus a 3 dB improvement in SNR. Distortion improves to the extent the two sides are matched; ideally even-order distortion is completely canceled (odd-order distortion is not affected).
The SNR and distortion improvement is not related to cable length except as regards to noise rejection. Ground loops are not a wiring "problem"; they are a fact of life when you have different ground paths in a system. They are pretty common in audio systems, home or pro, as evidenced by the many threads on the subject. At least in my experience they seem fairly common. So I would not discount that advantage.
As for noise rejection, many consumers bundle wires together for a "clean" look and that can lead to noise coupling. A balanced connection better rejections LF and HF noise. LF noise is usually inductively coupled by adjacent power lines. HF noise can be injected directly into the power lines or radiated and injected "over the air" from things like switching power supplies, dimmers, refrigerator and HVAC motors. In one case an aquarium pump was the culprit. The cable lengths do not need to be long, and in most but not all cases low-level inputs like phono inputs are most affected. However, I have seen plenty of cases where RFI was coupled onto line- or high-level cables and caused problems. Having balanced cables that isolate the signal path from the shield provides greater immunity to LF and HF noise sources. Again in my experience, which may not match yours, there are plenty of noise sources in the home that problematic. Aside from my systems and that of some friends (plus the 'net, of course), most of my experience in this area is from years ago when I was helping to install home and pro systems (hundreds of them) and, while I would not say the problems were really "common", nor were they at all rare in home installations. Since those years I have helped many friends deal with noise issues, and dealt with them in my own systems through the years (then and now).
It seems our background and experience is quite different on this subject. It happens.
Balanced differential is not in general the same as bridging amplifiers for greater voltage swing; bridging offers some of the benefits but generally in a lesser way, and additional drawbacks.
