Bird_of_Hermes
- Joined
- Jul 12, 2023
- Messages
- 33
- Likes
- 11
Hello all,
I have a question about amplifier gain and the impact that XLR vs single-ended cables make.
I am in the process of buying a DAC and amp. I plan on using a NCx500 amp with the default Hypex buffers: 11.5 dB and 26.8 dB gain which respectively correspond to a voltage of 14.2V and 2.16V to reach their max power. Let's go ahead and ignore that 11.5dB gain option. If we take the normal/modern DAC spec of 2V unbalanced and 4V balanced output, is there any reason I should choose to use the XLR output for a short cable (just a few feet) run?
I am sure this is silly, but I feel like I would be doing something "wrong" not to use the balanced connection over the single-ended one, especially when the amp requires the balanced cable.
I suspect that any performance increase from using the XLR (via the reviews such as this: DMP-A6) is simply due to the 6dB higher output level of the XLR connection. I feel like all I would be doing by insisting on the balanced cable would be to reduce the total usable digital volume control of the DAC. I would need to drop 6dB of voltage just to get it to the 2V max output level of the amp/buffer, then drop another few dB because my speakers (300W at 6 ohm) certainly can't handle as much power as the NCx500 can output (probably ~500W at that impedance)... and neither can my ears... or maybe even my neighbors' ears. And even then it will be blisteringly loud.
It's worth noting that I would need to get a RCA/single-ended to XLR cable as I still need a XLR connection on the amplifier side.
I am sure this has been posted before, but the correct search terms elude me. Please forgive my first post!
PS. Perhaps someone can help me with the math, but from the streamer linked above, Amirm reduced the output by 2dB to reach a 4V output voltage. Which, if the website I found is correct, should have resulted in a max voltage output of 5V, but he had indicated that the max was above 6V!
If I change the calculation to 4dB, as if the streamer was showing power gain instead of voltage gain, the numbers seem more reasonable: 6.34V. I am not really sure what to make of this.
