charleski
There are good reasons to use balanced connections in professional applications. You're looking at long runs (tens of meters or more) of cable that sometimes has to carry very low-level signals (such as for microphones), so noise immunity is an important concern, especially as cable placement is something you may not be able to control. But is there really any point in using them in a domestic setting? If your cables are 50-100cm and you're handling signals running at 0dBV (which is true of most DACs these days), then will you see any benefit at all from a balanced connection?
Obviously there are lots of subjective reasons to prefer balanced cables: they're 'professional', they've got big chunky man-sized connectors that lock in place with a satisfying click, equipment with balanced I/O will always cost more because it needs to handle twice the signal paths, etc. But if we're aspiring to be rational audiophiles, then none of this carries any water. I've noticed lots of comments in favour of balanced connection, but they really just seem an expression of preference. If balanced is really superior (in a domestic setting), it should be possible to measure this. Has anyone done that?
I suppose there might be certain situations in which you run into a ground-loop problem where a balanced connection offers a simple solution (though it amounts to avoiding the problem rather than removing it). But I've been using single-ended cables for 30 years without any issues, so I think that's a fairly rare and specific circumstance. I suppose people will be able to think of other sorts of anecdotal accounts, but I'm really interested in finding out if there's any data on this.
