Received my LX on 3/25, I have been switching back and forth between the Polk R200 and the Axiom M22Ti(been using it for 20 years now). In the very beginning, the top end from LX was way too laid back, and being perceived as lacking in detail, and almost seemed muted when I compared it to the R200, and M22Ti (Titanium tweeters). I had the LX from PC>Topping D10S>NC252MP initially. But the REW measurement showed the LX has plenty of detail though, just that for the longest time I was used to the elevated 10Khz~20Khz range from the Titanium tweeters. lol
On 2nd day, I used the Denon X1800h as a preamp and took out the Topping 10Ds DAC, from PC >X1800h>NC252MP and turned on the SVS sub, once I ran the Audyssey, and adjusted a few settings, the LX woke up immediately, as if I removed a wet towel draped over the speakers, it was a night and day difference, a lot more detail in the mid and up top, and a hell lot meatier and punchier down low with the addition of SVS sub. I had to measure and tune the setting many times to get it to where I was happy with the result in my office.
Instrument separation is very good, mid range is buttery smooth, both male and female vocals are fuller, rounder, a bit warmer, and sound more natural and realistic, not as dry as R200 and M22Ti, I have been switching back and forth between them for about 5 days now. Plenty of zing and snap from recording with lots of Hi-hat and Cymbals without sounding shrill, metallic, or edgy, very pleasing and easy to my ears. LX’s imaging is more precise, and also has deeper and higher sound stage as well.
Bass extension from these LX without a sub is very good in my small office, it’s even more unreal in a much bigger living room, the LX went down to 30hz then roll off smoothly (see measurement below). Running LX alone probably would be fine and sufficed for a lot of other people, but I ain't other people, I’m a bass head and I always need a good amount of bass energy that would cover down to single digit Hz for movies and games that I could feel, even at moderate listening volume. There's simply no replacement for displacement, I will always run subs even when i get around to buy the ELX towers in the future.
Sensitivity:
I measured the R200 to be about 4dB higher than LX at the exact same gain level; But since I usually only listen to music at around 75~80dB, and 85~90dB peak for movies and games, sensitivity isn't a real concern for me, but if you need to play them at concert level, the LX could handle a ton more power if necessary, 350~500W.
What I like about the LX:
-It's textbook linear in my room
-Silky smooth top range between 10Khz~20Khz, LX is VERY detail and respond well to tuning from Audyssey, I can listen to music, play games, and watch movies at higher dB level for much longer period of time without getting fatigue.
-Deeper and bigger soundstage
-Bass extension between 80 to 30hz is unbelievable coming from bookshelf at this size
-The bamboo cabinet feel a lot more dense and solid, build like a tank and very high quality construction
-Minimalist binding post
-Very good imaging
-Good sonic improvement over the R200 and M22Ti for me, in my application
-Great support from Dave and his team, super fast shipping
Subjectively speaking, these Titan dome tweeters are detail enough for me, I do not know what RAAL tweeters sound like so I have no idea what I'm missing out, if any. But so far I'm happy with the LX.
On-Axis. Here's my small office’s in-room FR measured with the REW+Umik1 at seating position about 5.5ft away, the LX are 7ft apart, and 4ft from the back wall, it's VERY linear and SUPER flat FR in my office: PC > Topping D10S > NC252MP > LX.
On-Axis. PC > X1800h > NC252MP >
LX plus SVS sub. Tuned with Audyssey, i'll continue to play with the setting to see if i could smooth out the region between 100~300hz.
