I've been able to find input selectors with attenuators (passive preamps?), and speaker selectors, but not an amplifier selector with the features needed to facilitate level-matched amplifier comparisons. I have not found a commercial product for sale that has the features I want, I cannot think of any other way to compare amplifiers properly via instantaneous, level matched comparisons - preferably double blind.
Basically, the concept is to switch either XLR or RCA between amplifiers, and simultaneously switch the selected amplifier to a pair of speakers, with the circuit designed to protect all components from shorts - and tube amps from open, no-load speaker connections. Also, some amplifiers - like my old Classé have internal switching to select the XLR vs RCA inputs, so I decided that it would be a more versatile design to do RCA vs XLR testing via the switchbox.
For me, the ideal switch-box would accept a single-source (a DAC in my case) signal via either RCA or XLR, and route it to one of two amplifiers via either XLR to the box, then XLR to an amplifier, or RCA to the box and then RCA to the amplifier. Or one could compare an RCA-connected amp with an XLR-connected amp.
Indeed, in my case, I could use my Topping DX7s to feed both the XLR and RCA inputs of the switch box simultaneously, and I could even use the box to compare an XLR input only amp with an RCA input only amp.
For level-matching, there would need to be a pair of high-quality stereo attenuators - one on each pair of inputs - and perhaps even a level-matching meter on the front panel. Assuming that testing would be at medium to loud levels, the common problem of low-level channel imbalance with attenuators using continuously variable wipers - rather then discrete resistor elements - should not be a problem.
In the same box, and switched at the same time, would be the amplifier to loudspeaker connections. It would be best to switch the two amps between the loudspeaker and a dummy load, because no load and high gain can apparently damage tube amps due to shorts occurring in the output transformers.
I haven't drawn a schematic in years, and never was an expert, but this might be fun to try. I did an internet search, and was blown away by what I quickly found at CircuitLab.com - a free electronic schematic circuit builder that is extraordinarily simple and intuitive. Looks like more fun coming up for this old audio and electronics hobbyist. The principle is simple as far as electronics go - a box/case, some RCA and XLR jacks, good switches and attenuators, and speaker binding posts.
First questions:
What would be a good resistive/inductive dummy speaker load (type and ohms) that would protect amplifiers without getting too hot?
What are the parameters for input attenuators for such a device?
First questions:
