- Joined
- Sep 10, 2020
- Messages
- 103
- Likes
- 318
The impedance of the load will affect the high-frequency part of the frequency response. The lower the impedance of the load: the high-frequency drop will drop downward. The higher the impedance of the load: the high frequency part will rise upwards. The actual value of A07 MAX load impedance from the 4-8 ohm range will not exceed 0.8dB
It shows nothing of the kind. That's a single frequency response plot, which means it's with a single impedance load, and so by definition it cannot show whether or not the amp is load-dependent. As @BeQuietZen notes above, it's most likely that this frequency response sweep is with a 4-ohm load, in which case it's the same as the 4-ohm response for almost every load-dependent Class D chip amp Amir has reviewed.
So IMHO it's far likelier that this amp is load-dependent.
