AirPods Pro II measurements? Holy bass batman!
Nwickliff
Has anyone seen the measurements on these headphones? I recently got mine and immediately switched the tips out for some foam tips and holy crap, the bass!!!!!! I don't think I've heard lower in my ears before and I'm including over-the-ear cans. With noise cancellation on these things are just incredible. Just wanted to find some measurements to back up what I'm hearing.
phrwn
N
Nwickliff
Nice! Thank you. I did boost the treble just a bit. That's impressive as it looks like almost 5db at 20hz! These things bump and you just can't beat the convenience. I also wonder how much bass is gained with the foam seal vs the silicone tips.
Yasuo
All About That Bass
staticV3
More measurements by 0dB
And Crin's data compared to what I consider neutral:
phrwn
Possibly no discernible difference since they have dynamic EQ.
Chromatischism
D
Deleted member 48726
Guest
I don't like raised response at high frequencies. Can they be EQ'ed from the iPhone?
MayaTlab
There is no system-wide EQ on iOS and you can't directly save an EQ profile on AirPods, but I wouldn't get too hung up on the 6kHz peak shown on Crin's measurements with ANC on anyway :
Generally speaking, not only do I prefer not to nitpick in terms of target adherence with IEMs and 711 couplers for a start, for the APP2 I'd also take the results with a pinch of salt until the feedback mechanism has been figured out (I don't think that it's quite as straightforward as the H1 chip AirPods when ANC is turned on as a little test with pink noise can suggest - the 1kHz+ region in particular might be quite interesting to investigate).
N
Nwickliff
I literally made this post because of the perceived difference. Which was strong enough for me to take the time to create a post asking about the measurements. Then find a graph that corroborates my initial perceived change. Gonna go ahead and conclude it’s a discernible difference.
Or are you chalking it up to a possible eq change and not hardware change? Either way the bass is definitely greater. I wasn’t expecting it or listening for it but had several jaw dropping moments while listening.
I run 2 18” ultimax sealed subs for my main listening in my living room with two open baffle speakers each with 15” woofers so I know what good 20hz sounds/feels like (with measurements to back it up). Not a flex as I’m sure other can wipe the floor with my system, but just to give context that unknown what good/even bass extension sounds like.
Peluvius
Have you tried the personalised spatial audio?
N
Nwickliff
Yes. Don’t know that I’ve noticed a difference from the the OG pros but it sounds good. I’ve listened to it long enough that I now prefer it to regular stereo. I don’t use the head tracking though. Also pretty sweet when connected to Apple TV when my kiddo is asleep.
Neddy
Wisconsin
