If it's bass it's not localizable anyway. To the degree it's at the upper end of that range I think it still works fine, they just have modifications to try to cancel room effects.Would ART struggle with using a phantom center setup? Been trying to wrap my head around how it would handle support when the front L&R are both playing the same mono signal (the center).
It’s still two channels playing content doesn’t matter what content works the same. Only difference is you losing LR that usually are capable and would support ART and in phantom center setup LR are loaded with C so last thing you would want them to do is to support cancellation as well.Would ART struggle with using a phantom center setup? Been trying to wrap my head around how it would handle support when the front L&R are both playing the same mono signal (the center).
I would estimate they would just support the left and right speaker as usual. It's only <150Hz, there will be a lot of mono content anyways there.Would ART struggle with using a phantom center setup? Been trying to wrap my head around how it would handle support when the front L&R are both playing the same mono signal (the center).
Any update on the HTP 1 and ART?Monoprice HTP-1, Denon/Marantz also has mentioned possible ART support in 2024.
Not really, it's still in (active) alpha testing and development.Any update on the HTP 1 and ART?
Sorry, I haven't properly compared and currently my subwoofers are not operational (I'm painting their diy cabinets) so can't test right now.@TimoJ Bro! I'm interested in an off-topic question. Alas, I don't know the configuration of your room, but the question concerns the audibility of low frequencies in rooms adjacent to a home theater. How different is the sound pressure emanating from the listening room when the ART is on and when it is off? Is it possible that turning the ART on increases the sound pressure outside the listening room? Unfortunately, I don't have a separate room for home theater, and a full room inside the room is impractical in my case, so I'm worried about not hurting the neighbors more because of the bass
I think you only remove room resonances from the measured when flattening at the measured position, not from the entire room. If there is a build up by some ventilation or a non-solid core door it will travel.When the "chancellation" from ART works it really should reduce outside SPL - but I don't think it's a lot. But I see no reason that it would increase it.
Simply EQ to flat already reduces outside noise cause when you fight those +15db room resonances these can't disturb the neighbourhood as much.
The recent StormAudio webinar discussed these thingsQuick few questions:
1. If ART goes only to 20hz what happens with below 20hz output. Is it filtered out with HPF?
2. If I have subs going to single digits in the room is there any way to use ART and get that output going?
3. If ART works below 150hz does it mean that over 150hz DIRAC Live takes over or if we use ART it just do correction in 20-150hz range?
4. If DIRAC Live kicks in over 150hz and we manually limit correction to 150hz would it mean that we get ART only without DIRAC Live engaging?
Thanks
