- Joined
- Dec 13, 2023
- Messages
- 33
- Likes
- 88
The Salnotes Zero timeline is the best timeline. Now to happily await my spent savings on speaker setup goodness like a Topping D90 PRO Sabre and Hypex Nilai500DIY 250W Stereo Amplifier Kit.
Yes, Linsoul is just the dealer / importer. For whatever reason they always put their brand in front of the actual manufacturer and product name in their listings.25 bucks?? This really is beer money. I'll get a pair after Christmas.
Edit: I'm seeing similar products on Amazon and ebay with the Linsoul, Truthear, and Salnote brand names but all with 7 Hz and Zero somewhere in the names. These look like the Linsoul ones on Amazon. Is that correct?
So these or the original Zero
I’m not so sure. With all that bass Amir is talking about you might hit the brown note. (J/k of course!)And no risk of diarrhea afterwards
Avoid sony products like plagueHave you tried the Sony WF-1000XM4? These are BlueTooth but sound surprisingly good with realistic bass. Somehow they manage to be really comfortable and and also stay put. They have active noise cancellation as well. <https://www.sony.co.uk/headphones/products/wf-1000xm4> There's now an XM5 but I don't know if they are better or not.
Well, a s.load of bass is a s.load of bassI’m not so sure. With all that bass Amir is talking about you might hit the brown note. (J/k of course!)
The price to performance is so disproportionate I feel like there should be a catch. I bought the original Crinacle Zero for $50 and they are my best audio purchase to date, I let a friend borrow them and accidentally converted them away from wireless earbuds instantly.
Given the excellence of these inexpensive IEMs I wonder how much longer companies manufacturing IEMS costing thousands of dollars can afford to do so? Especially when the performance of their mega dollar IEMS can often fall short of IEMS like the Crinacle Zero.Another el cheapo top performer.
That said, it wouldn't be a sin IMHO to include more decent tips "for a few dollars more"
Exactly my feeling. Luckily I'm pretty happy with my (sunk-cost) over-ear headphones. It would be harder to justify the expense when these cheap IEMs sound so good.well, the bright side is you can still by this cheap IEM and enjoy music for however long you can then leave it in a drawer without feeling guilty. I love IEMs when travel and at work but never be able to listen more than 3 hours straight.
I have to say that I really like the red tips (on the OG Zero). They just slide right in and seal with no fuss every time and their flexibility makes them really comfortable. And they're holding up very well after 10 months of daily use. Of course these things are very personal.Another el cheapo top performer.
Along with a bass shelf that's pretty much how I EQ my trusty old Ety HF5. Instrumental timbres still don't sound quite as convincingly natural as with the OG Zero. (Higher distortion could be part of the problem.) But it's more than acceptable when I really need the isolation.Not a catch as such but no new IEM releases seem to be designed to optimize noise isolation. There have been a few with unvented designs (e.g. using multi-BA configuration) which could be better for isolation but they haven't been marketed as such and are not affordable like these Zero models.
I would like to see anyone try to compete with Etymotic by making a completely unvented IEM designed for deep fit with double or triple flange tips for best isolation. I think Etymotics are great but after years of listening even I've decided the region 1-2kHz is too elevated and EQ it down by 3dB. I've recently been experimenting elevating around 8kHz and preferring the added treble response here too. It gets it a bit closer to Harman 2019 but not quite, like this Zero:2. So I think there is room for a company to improve on Etymotic's tuning in a highly isolating deep fit IEM.
To @amirm :
On this point I'd really like to know what your take is on the impact of ear canal resonance? This could also be considered a "catch" by proponents of Etymotics, which insert so deep the resonance is pushed up into such high frequencies it becomes less intrusive (above 10khz). The argument is that the resonance peak is artificially created by creating a closed tube of your ear canal between the mic/ear drum and IEM, which isn't apparent in speaker/headphone listening, so detracts from sound quality. Hence the deep insertion to ensure it is as high frequency and least likely to be heard as possible.
With the IEMs you review is the resonance peak at 1/2 wavelength of the closed tube created in the canal something you perceive or find impacts audio quality? I believe the coupler you use has some kind of dampening so this peak isn't as pronounced as for example on @crinacle 's coupler, though it would not match up with what is heard anyway due to the length of everyone's ear canal being different.
For reference, Crin's measurement of Zero:2 (EQ is Amir's settings), showing ~6dB peak at 8kHz :
