Zero 2 is the best tuned one and also the cheapest one by a huge margin. Seems like an obvious choice to me. What other IEMs do you have and like for reference?Sizce hangisi? kinera odin( 1. nesil) earonics corsa,zero 2
Have you had a chance to try Kinera Odin?Zero 2 en iyi ayarlanmış olanıdır ve aynı zamanda büyük bir farkla en ucuz olanıdır. Bana bariz bir seçim gibi görünüyor. Referans olarak başka hangi IEM'leriniz var ve beğeniyorsunuz?
Honestly, no. Hence I won't be disparaging it simply on the basis of the graphs and price alone, at least as ardently as some people might be inclined to. But it definitely has a "niche" sound, that might both suit you nicely and turn out to be an utter disappointment. Especially for that kind of money. So, personally, I would discourage you from buying them blindly. If you have hybrid IEMs with good treble extension, I'd suggest at least trying to EQ them to Odin's FR as a target to get a little taste of what it's like. It won't be an exact match, of course, but should be enough to give you an idea whether you want something like that or not.Have you had a chance to try Kinera Odin?
Try removing the shrink on the Zero cables first if it has a chin woggle (I can't recall)Slightly Off Topic.
I'm finding the heat-shink or whatever sleeve on the left IEM is slightly in the wrong place and makes a bit irritating compared to the right which I don't notice at all when I put it on. How is the Tripowin Zonie in this regard?
I'd rather not spend almost as much as the IEM on a cable, especially such a short one, but if it's quickly comfortable than it makes it easier to take the IEMs out and put back on.
Currently running Kenable 3.5mm extension cable from Tempotec Sonata HDPro, into the long extension cable that came with the Superlux HD668b, then to the IEMs or whatever headphone. Multiple connections are always are bad thing, but meh, no issues heard so far![]()
Hmm, I do like that they curve and the chin toggle, when done too tight it just as annoying. They are better when the cable is ran behind my back.Try removing the shrink on the Zero cables first if it has a chin woggle (I can't recall)
Nick the end of the shrink at the amp end and unpeel. Mark the front /back of the 2 pin connector before doing it.
The chin woggle enables you to pull the less rigid cable snug behind your ear.
Yes the zonie does too. There is a yinyoo that doest for about the same price.Hmm, I do like that they curve and the chin toggle, when done too tight it just as annoying. They are better when the cable is ran behind my back.
If the IEMs are held vertically, the left cable kind of stays fairly flat whilst the right tends to go in wards a bit more. The connectors were clearly designed with an angle yet the left cable defeats it's purpose!
I might have to look at some other shrink wrap stuff and see if I cannot remove and replace whilst keeping cable in the right position - sounds easier than it would be in practice.
The Zonie cable has these shrink wraps too?
You can try warming the left shrink with an hair dryer and see if you can reshape it a bit, keeping it curved inward until it cools off, i did it long ago with the QT5 cable and a TRN cable to make the hooks less aggressive.Hmm, I do like that they curve and the chin toggle, when done too tight it just as annoying. They are better when the cable is ran behind my back.
Spot on! I dug our little apparatus that looks much like the one in your posted image. I've a couple of wooden clothes pegs attached for less aggressive/biting grip. The hair dryer set on the high heat setting did the trick, then clicked it to cold-shot to 'set' the thermoplastic tubing.You can try warming the left shrink with an hair dryer and see if you can reshape it a bit, keeping it curved inward until it cools off, i did it long ago with the QT5 cable and a TRN cable to make the hooks less aggressive.
No need for other tools but much easier if you have something like this
7 Hz. Good.Zero 2 is the best tuned one and also the cheapest one by a huge margin. Seems like an obvious choice to me. What other IEMs do you have and like for reference?
A $10 Apple dongle is all that you needAnyway they are so good I can hear the noise from the headphone socket (realtec 1220 sound card) of the pc for the first time. Or at least that is what I think it is. irritatingly this means I need to spend some money (not a lot of money admittedly) on a DAC to clean up the signal.
A $10 Apple dongle is all that you need![]()
CX dongle is even better.A $10 Apple dongle is all that you need![]()
For you this iem is a great start; for me it's a great ending. Both of us are happyThanks - I was thinking anyway the Qudelix for all my HPs off my PC which is my normal usage. I'll get a dongle for the phone though as you say. On these IEMs I noticed the buzz for the first time. I guess IEMs are more sensitive to noise. I have Sony Bluetooth IEMs XM4 and they are totally dull in comparison and thin. Never really liked them and I think they cost 10x as much. First time I have tried wired IEMs.
