Please tell me more.
If I measure at L300 as you say, what am I measuring and why am I measuring it?
You are evaluating the output resistance of the amplifier and how it handles back EMF.
You can also feed each channel with 2 non related frequencies.
The amplifiers are assumed to be identical. When I measure at the Error Amp input of shorted input amplifier I am measuring exactly the same feedback voltage as in the driven amplifier.
At the - input of the error amp you should see no voltage as it tries to keep the input voltage 0.
When you measure with a scope at that point or other equipment you will see noise and perhaps other things that aren't there in reality.
The - input is a current input so there will be nothing to measure there.
What you want to see is the output of the amplifier as that is the - input differential to the + input (which is 0V) amplified by the amps closed loop gain and easy to measure as you don't influence and potentially destabilize the feedback loop by inserting capacitance to ground at a sensitive point.
Later after measuring things with the 500Watt 8Ohm load resistor I will connect a sealed enclosure sub-woofer and watch and measure the feedback voltage and phase as I sweep the frequency through resonance.
While this thing is open on the bench I will measure what you are speaking about as well. Tell me more about what results you are expecting to see.
Thanks DT
Depending on how good the feedback loop and output stage are you might see issues with output stages having trouble with inductive or capacitive loads having to supply (damp) currents that are not in phase with output voltages.
Any signal you will see (on a scope or recorded with a sound card) that are measured before L300 is where the feedback loop/amp fails to deliver current.
The more signal you see there the more the feedback loop is compromised because of back EMF.
The more you move your test probe to the output post (after L300 or heaven forbid at the binding posts) the observed signal (when in phase and with a linear amplitude) will actually be Ohmic losses of the L300 and internal wiring of the + and - output wiring.
It is essential to observe before L300 and put the ground test lead as close as possible to the 'ground' of the amp module.
Not to the chassis or - binding post.
