1DIFFSYM2QC type S class AB audio Amplifier
modulardesign
1DIFFSYM2QC Audio Amplifier
$120 mono, $240 stereo
free shipping and protection module for email order
Datasheet
M
modulardesign
The free shipping and protection module offer has now expired.
M
modulardesign
PM me to get these at 30% off for this month. No limits
M
modulardesign
For this month fully assembled modules 2 channels including shipping $200
M
modulardesign
This has offer has expired and now you can get the modules direct from the store
M
modulardesign
Damping factor 1600 into 8 ohm, perfect 100k square waves
M
modulardesign
Same SYMEF type S midrange with multiple layers and textured 3D palpable sound stage. Difference between this and SYMEF type S is that this has multi layered textured highs while SYMEF type S has multilayered textured bass, very few amplifiers can match let alone unseat SYMEF type S bass rendering. However many people are bass texture deaf in which case this is the better amplifier depending on your hearing. Both this amplifier and SYMEF type S are stable even with loss of compensation. Now accepting Christmas pre orders. Best wishes
Max specs for both Amps with suitable protection modules
1DIFFSYM2QC TYPE S
800VA 45V TRANSFORMER stereo
Per channel
173 Watts 8Ohm 0.01% THD (13600u per rail)
291 Watts 4Ohm 0.01% THD (13600u per rail)
477 Watts 2Ohm 0.08% THD (13600u per rail)(Risk of transformer failure use fuse on primary)
M
modulardesign
Here's Dr. Stephens latest build of the DC servo variant 1DIFFQC SYMPHONY
M
modulardesign
M
modulardesign
The 2SD2560 with hfe 30000 ft 70Mhz, cob 120pf needs a little slow starting. Look out for the next video where Dr Stephen slow starts the output stage with some base resistors on the drivers
M
modulardesign
While single integrated Darlington's may not need base stoppers, paralleled integrated Darlington's are no less than mosfets, use base resistors if used in parallel, testing took place under current limited lab supplies so no output devices were lost
