1 bit DAC launched by TOPPING
312elements
Chicago
Would be pretty awesome if there was delay on the PEQ for using multiple DAC’s (3 way crossover or even multichannel).
Reactions: Tim
1
192kbps
With IEMs, of course, there are also headphones. With audio interfaces, of course there will be microphones, and there will also be better audio interfaces. After all this, let us look forward to Topping speakers.
boxerfan88
The new 1-bit DAC looks very nice. The conversion module has a lot of components for a 1-bit DAC.
Could it be multiple concurrent 1-bit DAC followed by summing all the outputs?
I am looking forward to seeing the measurements…
Rhamnetin
I expect ES9039 based DACs to still measure best.
Somebody has to make a dac for suckers sorry audiophools
SMSL has been making more audiophool oriented products with their current VMV flagships, now it's Topping's turn I suppose.
DLS79
United States
Maybe its just me, but the D50 III & A50 III look wider than my D50s and A50s. Also the A50 III has 3 gain settings while my A50s only has 2.
Hopefully the D50 III has a better screen than my D50s.
@192kbps Have you seen anything that confirms the D50 III has PEQ?
sarieri
D50III is most likely utilizing PEQ from the XMOS chip. It’s gonna be much harder to implement this to a multi channel DAC.
August
It's very blurred, is it really "hana"? Tanchjim already used that name for a well known iem.
Sokel
Stack 16 of them in a box to compete with normal current DACs. This is dumb. Why go backwards? No advantage to DSD and no advantage to this.
I guess it might sell to the people who like PS Audio and believe subjective reviews.
You never know until you measure.
It's not the format,it's how a device handles it,at what conditions,level,etc.
It's easy to measure and decide for yourselves:
Brian Hall
Southeast Oklahoma
Data is data. Bits are bits. As a recently retired software developer I can state that it is more of a pain to recombine an incoming stream of bits and deal with a lot of bit twiddling than to deal with bytes and words of data.
The only time dealing with 1 bit at a time makes sense is when you need to monitor something that is on or off or setting some condition. If we need 16 bits to represent a sample of the audio, then give us 16 bits. Or 24 if we are recording the audio and need to modify it.
There is no benefit to complicating a job like this by requiring extra steps. Just because something can be done this way doesn't make it a good idea or beneficial in any way.
Sampling millions of times per second like DSD is one of the most ridiculous things I have ever heard of. Very inefficient and just a ton of wasted data. Does everyone understand that DSD has to be converted to PCM to actually do anything useful with it? Working with it in PCM format and then saving it back to DSD never accomplished anything and can't improve the sound.
CD quality sampling at 16/44.1 means you are getting a 16 bit sample 44.1 thousand times per second. There is no useful data between those samples since we only need to capture frequencies that humans can actually hear and discard the rest. That is a solved problem.
Does the 1 bit processing somehow improve filtering? No. We can already filter out all the unwanted noise to a point way below audibility. 1 bit is a fraction of a useful sample and has to be combined with a series of other bits to represent a moment of time. 1 bit only allows you to say move the sample up or down by 1. Yes, you can do that millions of times per second but you gain nothing by doing it that way.
This looks like a gimmick designed to appeal to audiophools. Snake oil. People like PS Audio are probably already fast at work on their own version of this since Paul believes DSD is somehow better than PCM.
solderdude
The Neitherlands
I take it that this isn't the same as the Philips 'Bitstream' of old/Technics MASH type of circuit which claimed to be a kind of 'one bit' decoding...
MASH is 4 bit DS.
TDA1305 (bitstream) = 5 bits
SAA7322/3 (256x OS) and SAA7350 (384x OS) were true 1-bit DACs
Sony had 1 bit pulse length modulation converters (like CXD2564 = 768x OS for instance but Sony had several chips like that).
Bleib
Sweden
Interesting (PEQ in particular), hopefully we also get BT remotes
