1 bit DAC launched by TOPPING
1 bit delta-sigma modulator means DSD? Like PS Audio does, except Topping's DACs will measure a lot better.
Finally PEQ in their DACs, that is the most important news IMO.
Curious about the IEM too.
You can plug-in 6 headphones at once. :p I assume the firmware allows you to adjust the volume individually but knobs would be more convenient.
Multi-output headphone amps are common in recording studios, radio stations, and other professional situations.
I also see multiple connector types so you don't need adapters to plug-in a headphone with different connectors.
That or aimed at people with 6 ears :)
Yes I have seen those before, with lots of knobs. This seems more like for people with many headphones as you point out. Doesn't seem practical to have to go through push button selection to change the volume and end up blowing your buddy's ears.
Maybe with different EQ settings for each output?
PEQ is certainly of interest... although I expect they meant except there in brackets. ;)
JSmith
Excuse me! I take advantage of the photo in your post!!;)
well, an R2R Dac with those numbers would be very interesting.
Usually those levels with that implementation are much lower. Things seen only with traditional DACs with ESS or AKM chips…
Reactions: d3l
1bit MASH DAC Technics - 1989
I presume the "discrete" refers to the DAC and that the DAC is 'R2R', correct? ("Discrete" could also mean refer to substituting discrete circuitry for op amps in the analog stages.)
Sounds like Topping is pandering to audiphool trendiness.
The dac is not a R-2R dac but a 1-bit dac.
As a general rule, the fewer bits a DAC decodes at a time, the higher the oversampling rate needed to reach a high dynamic range
multi-bit dacs:
R-2R DACs can be designed to decode data without needing to oversample. The simplified explanation is that because they can handle 18-28 bits at a time, so they don't require delta-sigma modulators to clean up the quantization noise.
ESS/AKM DACs are also multi-bit DACs, but they use something called delta-sigma modulators to remove noise from the audible band. Since they decode only 4-5 bits at a time, they have to oversample to properly clean the quantization noise with their delta-sigma modulators. That's why they're known as delta-sigma DACs. They go through an extra phase after simple decoding to clear out the quantization noise. Perfectly matching the units in these delta-sigma modulators is one of the challenges in designing good multi-bit DS DACs
1-bit dacs.
1-bit DACs decode one bit at a time. Since they handle fewer bits at a time, they need VERY high oversampling rate to clear the noise from the audible band and boost the dynamic range. They must use a really complex oversampling algorithm to keep the dynamic range high.I remember vaguely that their output stage can be designed to be less non linear too for various reasons but for audio applications that doesn't matter.
all 1-bit dacs and ESS/AKM dacs are delta sigma dacs. R-2R dacs are ladder dacs.
Advantages of 1-bit dacs.
There's no publicly available, measured proof of the advantages of 1-bit DACs. Years ago, ESS released a presentation claiming that the non-linearities of delta-sigma modulators are audible. 1-bit DACs are said to possibly avoid this issue. Generally, it's believed they don't produce the non-PSS noise that ESS/AKM delta-sigma modulators do and they might have less noise floor modulation. But these points are still speculative. Despite this, it's actually tougher to design high-performing 1-bit DACs compared to, say, ESS DACs
Conclusion:
Chord specializes in designing 1-bit DACs. I think Topping wants to edge Chord out of the market with their new DAC. Topping leaves no room for the audiophile community to complain about the 'ESS glare' or the 'soft sound' associated with AKM. They've developed a completely discrete DAC that addresses all the common complaints audiophiles have about the perceived problems with the sound of AKM or ESS DACs which they claim ''these are not measurable with simple methods but we can hear them''.
Topping has already won over the hearts of evidence-based audiophiles. I think their new goal is to win over the 'I trust my ears' crowd.
About the claims of non-pss noise etc check this thread: https://www.audiosciencereview.com/forum/index.php?threads/two-old-ess-talks.9216/
I had a 1-bit one. One bit with 5 disc rotary player. My sound improved overnight when I replaced it. I know you’re not supposed to be able to hear the differences between DACs but it was bad. JVC I think.
Reactions: pma
That is probably more the analog stages or sighted bias. The JVC K2 era CD players measured well.
Technics SL-PG100 sounded bad as well. The flaws were above audibility threshold. Digital flaws - spurious frequencies. Especially at low level.
Not necessarily:
multi-bit dacs:
1-bit dacs.
Conclusion:
Chord specializes in creating 1-bit DACs. I think Topping wants to edge Chord out of the market with their new DAC. Topping leaves no room for the audiophile community to complain about the 'ESS glare' or the 'soft sound' associated with AKM. They've developed a completely discrete DAC that addresses all the common complaints audiophiles have about the perceived problems with the sound of AKM or ESS DACs which they claim ''these are not measurable with simple methods but we can hear them''.
Actually chord is n bit Delta sigma. Aren't they?
Maybe I'm wrong
I too had a 1-bit DAC, or so it claimed to be. That was a Technics SL-PS70 that I bought around 1991. It wasn't as good as later DACs that I've owned, but was a big improvement over the Yamaha CD-X1 I'd been using before, bought circa 1985, that had a very nasty treble.
Topping does not have PSAudio's wacky bearded guy designing its 1-bit DAC, so I'm afraid it will be unable to compete.
