Holy moly those B&Ws are bright there. can't tell a damn thing else, it's all reverberant room sound.
Can presets for levels and other adjustments be stored in memory on a suitable audio mix console?Yeah, everything would want to be as near to identical as possible, to gain maximum value.
I know this. I'm curious about what a inexpensive console costs for software or hardware.The problem is that your speakers cannot possibly sound like his speakers... no matter what you do.
From the pre-amp side to level balance at the amplifier inputs ... they can be quite inexpensive. A simple 4 track audio interface should be able to do the job.I know this. I'm curious about what a inexpensive console costs for software or hardware.
Nobody is claiming perfect resolution in these videos (this is the reaction, rather than reading) and nobody suggests that the qualms raised don't have value (different rooms to yours, mic response and so on), but to say that videos, especially well executed comparisons between different speakers (yes, even when played back through your own speakers or headphones) don't give an impression of how a speaker will sound, is logically false.
So like $200 for something that can work at the required standard of accuracy req'd plus including cables? Then + expensive mics, a booth or suitable room. Could get messy.From the pre-amp side to level balance at the amplifier inputs ... they can be quite inexpensive. A simple 4 track audio interface should be able to do the job.
I suppose, but it could be done one at a time as you measure them, providing things were kept the same on subsequent occasions.But it won't and it is a lot of work and expense to host them.
This is somewhat adjacent to what I mean. I meant more how do objective differences in measurement affect subjective perception on a wider scale (groups, not individual). OK, everyone has different preferences, but there will be some degree of overlap.On the former, if your headphone is already a bass heavy, you may like a speaker with less bass using them which is not correct. And at any rate, everyone will have a different headphone so disagreements would continue.
Yep ... all that to finally discover the limiting factor is the speakers sitting on your audience's desks.So like $200 for something that can work at the required standard of accuracy req'd plus including cables? Then + expensive mics, a booth or suitable room. Could get messy.
The ultimate limiting factor is a lack of imagination. Obviously tablet speakers won't cut it, but a reasonable pair of two way speakers will convey the general character of any other speaker, when other comparisons exist (including the source material).Yep ... all that to finally discover the limiting factor is the speakers sitting on your audience's desks.
I watched one of those videos from my tablet and guess what ... it sounded just like tablet speakers to me.
It works perfectly fine as a rough and ready way to decide whether a speaker may be of interest for proper audition.
Yes, and that is just "rough and ready" put into different words.As I said, the closest you'll get is "This is what his speakers sound like through my speakers"
How does that reduce the work of capture, volume/location equalization, compression and hosting them?I suppose, but it could be done one at a time as you measure them, providing things were kept the same on subsequent occasions.
Believe me, if there is a solution for this, I would implement it. But capturing the sound and having people listen with every device they have is not it.That a speaker can present poorly on measurements, yet sound far better than expected suggests there may be some way to go in fully interpreting the measurements.
It isn't the only time you have been surprised how by much you enjoyed a speaker that didn't measure so well. It seems that, at the moment, measurements (or the understanding of them) are not giving a full picture as to whether a speaker will give a seemingly natural/pleasant presentation, even for a trained listener. Perhaps recordings, alongside measurements, would provide some extra information to bridge the gap...who knows?
Agree. Did that once, appreciated the service, but eventually it didn’t help me much.We hugely bemoan the loss of brick-and-mortar HiFi shops where we could audition speakers, etc. Yet, those who survived that era knew that listening to speakers in a HiFi store was much, much different than hearing them in your space.
Not if you're comparing the recorded tonality against the same source tracks. If the headphone is bass heavy, the source track will be bass heavy, and you would simply compare and make sure the recorded sample of the speaker being tested is also bass heavy. The listener isn't observing which one "they like on their headphones", they are observing which speaker sounds nearest to the source track. Your duty would be to make sure you eliminate as many variables as possible. If you have issues and gripes with how some do it, then do it better.But it won't and it is a lot of work and expense to host them. On the former, if your headphone is already a bass heavy, you may like a speaker with less bass using them which is not correct. And at any rate, everyone will have a different headphone so disagreements would continue.
It depends. 990 of the videos may have been recorded poorly over a cheap cell phone mic with insane amounts of room coloration, while the 10 were done right. I get your point, though. If you're comparing 100 videos that were done sufficiently, and you disliked 99 of them, then I would say its clear as day it's not what you want and the 1 was just an anomaly. There's a lot of garbage demo's on YT, but there's also some gems.I mean when I don’t like the sound in 990 out of 1000 videos of the same speakers in as many different setups and rooms, what will be the odds that they’re gonna work for me in mine?
Thank you for this perspective. Really appreciated and very understandable.Believe me, if there is a solution for this, I would implement it. But capturing the sound and having people listen with every device they have is not it.
