I remember I had this feeling of „big sound“ a couple of times and was only to quick to jump at “big sound = big speaker” analogy.
My first deterrent from this false, and poorly established analogy came when I had this “big sound” feeling from a small bookshelf speaker. It was one of the Sonus Faber’s. And these are notorious for having a deliberate sound signature.
Another clear indicator, I saw in the fact that speakers that played “big” had a huge, huge concentric driver.
I didn’t know of any 12” bookshelves, so I came to a conclusion I won’t be able to compare small speaker to a big one since a small one wouldn’t have such a big driver.
Then, a rather strange thing happened when I had B&W 802’s for awhile in my apartment. It was a Matrix 1 series which had a closed box for the woofers and for the mid. Funny enough, this big speaker with 4 woofers sounded smaller in my small listening room than the petite LS50 (a 6 litre enclosure).
Perhaps it was the smoother roll-off of the enclosed box with no port bump. So, in my small concrete room, big 4-driver woofers seemed to have less bass. I loved to listen to baroque chamber quartets on these, but not much else. I finally decided I can’t have speakers that (IMO) cover so few music styles.
Big ones went, the small ones stayed.
But the riddle of “small/big sound” (relates or not) to small/big speaker, remained. Mostly because of some small speakers sounding “small” and some sounding “big”.
At one point I thought I had it figured out when JA said this:
Fig.3 shows the farfield response of the '302—averaged across a 30 degrees window on the tweeter axis—spliced to the nearfield responses of the woofer and port, as well as the complex sum of those nearfield responses. The balance is slightly swaybacked,
a moderate rise in the high treble
being balanced by a slight
excess of upper-bass energy.
This kind of measured response does tend to make a small speaker sound bigger than it actually is, as WP found in his auditioning. The bass is to specification at 6dB down at 59Hz, the approximate frequency of the port tuning. Though the slight peak at 1kHz might make the speaker a bit unforgiving on recordings that are themselves bright, on neutral-balanced CDs it will usefully highlight recorded detail.
Sidebar 4: Measurements The DM302's specified sensitivity, 91dB/W/m, is high for a small speaker, but indeed I measured a B-weighted figure of 90.1dB/W/m—this mini will play quite loud with only a few amplifier watts. However, its impedance plot (fig.1) reveals that it drops below 4 ohms for...
www.stereophile.com
It sounded convincing, but some more neutral speakers than B&W is, also sounded “big”. How come? I was ready to accept it had to do with in-room response or the way the speaker was vocalized, but if the speaker is neutral, this should be coming from somewhere else.
And then Ethan Winer came with his short explanation of diffusion where he said that diffusors on a back wall created this illusion that the room is bigger than it is (since less sound is reflected back to the listening position, you get the feeling that it went away to the empty space behind you which is not actually there, it's at 02:04 min/sec).
That finally seemed like an explanation good enough for me. Well treated room may make your end result better, which you then ascribe to the speaker itself. This is why considerably large speakers like B&W 802, didn’t do any magic in my room – dividing the speed of sound to the length of my walls made it clear to me my small speakers are getting the reinforcement in the lower region around the port bump making them look like they have even more lows than they really do.
As far as the distortion from the drivers goes, if this is really the case, Meta should sound noticeably larger than original LS50’s going by the amount of the distortion they eliminated by the meta material.
We could ask all the members who had the experience with both if this is the case.
