I always thought it was technically defined as what you hear through the plankton.
I'm kinda disappointed to see a moderator piling on with the mockery. You guys set the tone.
I did, several times. In particular, I pointed out a small speaker [Spica TC-50] known for throwing an image much larger than the speakers. The Ohm F speakers throw the biggest sonic image I've heard so far, though they are not the biggest speakers I've heard. The Bose 901s throw a big image, are not particularly large. Similarly, the LS3/5a is small and sounds miniaturized.Nobody, as far I can remember, has talked about whether speakers sound big or small.
Plankton deserves to be mocked.I'm kinda disappointed to see a moderator piling on with the mockery. You guys set the tone.
Uh... 10x10?! Not an easy task to set them right.I did, several times. In particular, I pointed out a small speaker [Spica TC-50] known for throwing an image much larger than the speakers. The Ohm F speakers throw the biggest sonic image I've heard so far, though they are not the biggest speakers I've heard. The Bose 901s throw a big image, are not particularly large. Similarly, the LS3/5a is small and sounds miniaturized.
In any case "Your speakers are too small" sounds like a subjective judgement. Speakers can be appropriate for a given room, size is not the first or the most important consideration. Saying "Your speakers are too small" is a subjective judgement without evidence for proof. You can say the LS3/5a is too small, but that speaker still has a following, so the marketplace does not agree with you. I suspect there could be a DBT for this sort of thing, but it won't happen because the process is just too cumbersome. My speakers are small. However, they are totally appropriate for the 10' x 10' room they're in, the sub takes over around 100hz anyway. Different horses for different courses, right?
It's a desktop stereo. The speakers are a/d/s 400e, 11.75" x 7.5" x 7.75". I can watch movies on the laptop, the speakers reproduce mono as a hard center image, as if the sound is coming off the screen. Very useful for watching videos/movies. These speakers are as big as I can fit on this desk.Uh... 10x10?! Not an easy task to set them right.
Right, I'm sure it has been said a few times.Different horses for different courses, right?
It's my only system right now. Don't have the space for anything else.Right, I'm sure it has been said a few times.
Is that your main system?
Believe it or not for a while I had my Altec A7-500's and the 4 18 subwoofers in a bedroom 10 ft by 12 ft before my dedicated room was built. It actually didn't sound terrible.It's my only system right now. Don't have the space for anything else.
We know what 'dynamic range' is in audio. So we know what 'dynamics' are. They ultimately are changes in level.I am serious.
Why don’t you show me a paper written about it? Or do you expect us to accept that just because people on audio forums talk about it, it is a term?
If you can’t measure it, if it doesn’t have a unit, if there is no mathematical model of it, then it has no place in science.
Earth without it wouldn't be funny at all.Plankton deserves to be mocked.
I've had big speakers in small rooms. My first speakers were AR-3s, didn't do as well in my small room (49 years ago) as the a/d/s 400e speakers + sub I'm now using. Also had Big Infinity Bookshelf speakers, little [wimpy] Celestion, Infinity Primus towers, Vandersteens, Little Paradigms, little Klipschs. While I can imagine better and/or significantly different sound, what I have now works as well, and usually better, than any speakers I've had before.Believe it or not for a while I had my Altec A7-500's and the 4 18 subwoofers in a bedroom 10 ft by 12 ft before my dedicated room was built. It actually didn't sound terrible.
Under what definition does it normally need instrumentation or magnification to be perceptible?We know that 'micro' as a prefix tends to mean: very minute, normally requiring instrumentation/magnification to be perceptible.
Look, you are clever, we recognize that, but how can we be sure you too aren't either a bog standard audiophool or just toeing the party line?As it is used, it means nothing, or whatever audiophools want it to mean. It's really a claim about the smallest level change they can hear, but they don't even realize that.
I agree, but I believe that plankton is (are) plural -- if so, of course, the verb should be plural, too, i.e., deserve.Plankton deserves to be mocked.
Macro- and micro- are general purpose modifiers. In general use they simply mean large and small (respectively). As specific measurement nomenclature, micro- means one millionth. For audio dynamics, we generally use dB scale, which as we all know is logarithmic. If we use 0 dB as reference, then one millionth of our reference is -60 dB. The term micro-dynamics as applied to audio is usually vernacular, but -60 dB is a reasonable starting point if we want to get more quantitative or specific.We know what 'dynamic range' is in audio. So we know what 'dynamics' are. They ultimately are changes in level.
'Micro dynamics' if it had any serious definition, would be level changes below some more or less arbitrarily set level of normal audibility. One would expect 'microdynamics' to require a volume boost, to be perceptible.
On the main topic, I think macro-dynamics will be more of an indicator of "largeness" than the other end of the dynamic scale.No, a poster did provide a relatively comprehensive answer some pages back about how "micro-dynamics" might relate to directivity, larger speakers being more directional at lower frequencies.
If you go back to my first post:
That was what I said. I also added something, perhaps unwisely about micro-dynamics, which may well be a thing, according to some posters, even if the term is incorrect. The argument seemed more that the term was incorrect - because once described, a number of people provided better terminology for what I had described.
Ultimately, the posts of sarumbear, rdenney, even SIY agree somewhat with what was said in the quote above. They may not agree wholly, but each of these posters have given reasons why smaller speakers will be limited in SPL compared to larger ones/ones with more cone area. SIY uses drivers on the smaller side, but in a 4-way configuration with the 6.5" driver crossed to larger woofers at 120hz, 4th order. So, quite different than typical 2 way satellites + sub crossed at 80hz.
I will make a summary post for the thread so far soon.
MattHooper did go to bat for micro-dynamics quite vigorously, but micro-dynamics is not the main point of the thread, so let's move the conversation on. Some of the jokes were funny at first, but like all jokes, tend to become rather stale after the 5th, 6th, 10th time of hearing.
OMG, I believe you could kill somebody like that. LOLBelieve it or not for a while I had my Altec A7-500's and the 4 18 subwoofers in a bedroom 10 ft by 12 ft before my dedicated room was built. It actually didn't sound terrible.
True -- but, on the other hand, the Altecs also sound great at really (really) low volume, too.OMG, I believe you could kill somebody like that. LOL
Yes, it is. LOLOK, I know that's not really funny.
In the abstract, yes -- applied to an actual person, rather less so.Yes, it is. LOL
