Yaqin MC-84L Tube Stereo Amplifier Review
Rate this amplifier:
    Votes: 242 93.8%
    Votes: 5 1.9%
    Votes: 2 0.8%
    Votes: 9 3.5%
This is a review and detailed measurements of the Yaqin MC-84L Stereo Tube amplifier. It is on kind loan from a member and costs US $600 on Amazon.
The picture doesn't do justice to the nice design of this amplifier. The transformer case in the back nicely contrasts with the chrome parts. The latter does make the labels hard to read though when looking from above:
One set of binding posts is available for 4 ohm and the other, 8 ohm. Seeing how speakers don't have constant impedance, nor are advertised correctly as such, I feel bad for people trying to figure out which posts to use (common criticism for all such amplifiers). Let's see how it performs.
There is a headphone jack in the back which I did not test.
Yaqin MC-84L Stereo Tube Amplifier Measurements
For all but 8 ohm power test, I used the 4 ohm tap. Let's start with our dashboard:
We have the high harmonic distortion which we kind of expect. But a lot of mains noise comes along for the ride, causing intermodulation with our main 1 kHz, making for a mess. SINAD which is the sum of all unwanted "stuff," lands the amplifier at the bottom of our rankings:
Noise is a step above but still nothing remotely to be proud of:
Frequency response is flat enough if we ignore varying performance between channels:
Crosstalk is one step above mediocre:
You get a better feel for distortion when we use 32 tones to simulate "music:"
Not pretty. Same story for 19+20 kHz tones:
The amplifier is fairly rated at 12 watts, assuming you don't care about distortion:
One channel is having trouble above 2 watts which we also saw in the dashboard. So maybe it is a bad tube or something. Best of luck to a customer figuring that out without this type of measurement.
If we "only" allow 1% distortion and noise, available power shrinks to a trickle:
Yes, that is only 2 watts!
Using 8 ohm tap, we get similar results:
Sweeping frequencies we see the typical rise in distortion with frequency. But also increase in distortion at low frequencies (transformer saturation?):
I am showing both channels. Dashed line is the "good" channel.
Our power on/off test shows instability on top of noise at these events:
Fortunately if you wait a minute or so, everything stabilizes:
The Yaqin MC-84L made a very positive impression on me with its modest size and super nice industrial design. And reasonable price for such tube products. Performance though, set a new record with respect to how bad it is, taking over the slot for the worst measured amplifier to date. The amp has 42 reviews on Amazon with average of 4.5 stars. Folks must be very tolerant of noise and distortion out there!
I do like the company honesty when it comes to power rating and even SNR.
Needless to say, I can't recommend the Yaqin MC-84L valve amplifier.
Great review thank Armir but why you removed Pass ACA amp from ranking?
Aww yiis. My Luxman SQ-N150 is clawing it's way to the top of the tube heap!
Bob Carver breathes a sigh of relief.
Great! And what do we learn from this?
People are very subjective in their perceptions, many love this type of sound amplification even if it is as incredibly poor as in this case.
And that's a good thing!
Not only can one assume that the main focus is actually on the music being heard and its emotional magic, but also that it is an important basic requirement to go through life unscathed.
Imagine if people were ranked by their most disgusting smell, appearance and behavior... over time no one would be left standing.
Maybe those with perfection fetishes should enjoy their music through such tube constructs every now and then, purely for therapeutic purposes :)
Products like this, and a few others, give audio x a bad name. It creates an aversion for regular Joe to participate in the sport. You know how we all mostly fret over audio purchases? Well regular people fret over bathroom mats and paper towel holders, so when it's time to purchase a thing to listen to, they become gripped by indecision, with not much to rely upon other than Amazon reviews......specs and schematics mean nothing without a frame of reference. Do I want the 2 watt amp or the 2000 watt amp??? They're both the same price?!?!?!
Maybe North Korea can start a production line of SOTA tube amplifiers.
Don't laugh, after seeing this I'm serious.
This amp is a good match for vinyl - has similar SINAD to vinyl playback. I wonder how many bits of multi-tone "clarity" a vinyl playback chain has. 5? 6?
Vinyl has between 9 and 11.5 bit depth, last number I saw
An interesting question would be, vinyl verses MP3 (ducks for cover)
MP3 (alongside a number of other lossy codecs) should be good for about float24 equivalent if there were such a thing... you'll be hard-pressed to ever get an instantaneous dynamic range of more than about 16 bits out of it, but globally that chunk can be just about anywhere as amplitudes can be scaled almost arbitrarily. So if your MP3 encoder supports being fed with 24-bit or 32-bit int or even 32-bit float, there is no reason not to use that. This is how formats like Minidisc and DCC are technically capable of post-16-bit performance at macro level as well.
I reply in fact not to you, nice review I must admit, but to the “haters” that comment without having the knowledge for it
I have bought this amplifier an I use it in my holidays house, a flat, indeed small.
Well using it at low volume, I think 5 w no more, with high efficiency loudspeaker , it sounds very well , mid very nice, high very well represented, low frequency not so tight. But for the price is not bad at all. I have another equipment for my big living room that obviously sounds better ( but overall it costs 7k instead of 550 ) . When you do not need high power is really nice , for high pressure hearings obviously it distorce and it doesn’t fit for it. Also the Deckware sebaufo , gorgeous amplifier gives only 2,5 w . That which is really annoying are people commenting without knowledge , laughing etc. I am old , I plays piano and I have the absolute pitch and my ears “ have heard things you people would never believe “ to paraphrase Rutger Hauer speech in blade runner ( for example couple of mono krell amplifier driving the first magnet planar loudspeaker … and many other)
Thanks for your review very professional
The measurements that really suggest a broken design, the 32 tone and 19/20Khz 5watt graphs, are the result of a 'faulty' measurement. The peak to average ratio makes this power limited amp clip with these signals. Amir should have skipped these tests or scaled down the level to have an honest measurement. But still: -40dB distortion is lot. And most likely audible. Most likely a pleasant sounding distortion.
Reactions: MAB
This amp is a distortion generator. If you like distortion - fine, have at it.
But I don't need to have personal experience of it to know I want it no-where near my music.
Sorry, what knowledge are we missing? Amps are not some mystical device... they're just amps.
JSmith
I think he was referring to the knowledge of enjoining the listening experience of this amp.
I took it more as... "you can't comment on it as you haven't heard/experienced it". We have a full suite of AP tests on page 1, which more than characterise this amps performance, much more "knowledge" than any subjective impression. Maybe something got lost in translation...
JSmith
JSmith
Same as what I said?
