- Joined
- Dec 12, 2019
- Messages
- 14,247
- Likes
- 32,015
@patq2 we really would like to/are trying to help you.
You're talking about this?
If so, this is a very specialized driver designed for reproduction of low frequencies, including a built in amplifier and crossover network to use it as a so-called subwoofer. The subwoofer system is incapable of much midrange reproduction at all, and even the driver, if removed from the subwoofer and repurposed, will have very poor frequency response extension.
If you want to build a useful two-way loudspeaker system with a 10 inch woofer and a tweeter, and if the SEAS "A26" I mentioned earlier is too pricey for you, take a look at the forum and projects on PartsExpress website.
projectgallery.parts-express.com
You may find some good ideas based on some of Parts Express's own inexpensive drivers (e.g., the "Goldwood" line).
The Skar tweeter appears to be this one(?):
This "one inch" horn tweeter is sold under many different names, e.g., the Pyle PDBT28:
https://www.parts-express.com/Pyle-PDBT28-Titanium-Tweeter-272-115?quantity=1 (currently out of stock)
I couldn't find a frequency response curve for either of the above, but here is another very similar tweeter from Parts Express with very similar specs.
and here's the frequency response curve:
The nominal frequency response (per the website) is 2000 Hz to 20,000 Hz, but the response is only kind of flat from about 6 kHz up to about 16 kHz (rising on-axis response up to about 18 kHz).
Monolith by Monoprice M-10 V2 10in THX Certified Select 500 Watt Powered Subwoofer - Monoprice.com
Monolith™ by Monoprice™10" THX® Certified Select 500‑Watt Powered SubwooferMassive Output. Low Distortion. THX® Certified.The Monolith™ THX® Certified Select S
www.monoprice.com
Forums - Techtalk Speaker Building, Audio, Video Discussion Forum
vBulletin Forums
techtalk.parts-express.com
Speaker Projects | Parts Express Project Gallery
VX35-ST | 3.5" Titanium Bullet Super Tweeters - Pair | Skar Audio
Skar Audio's VX35-ST 3.5" titanium bullet tweeters are ridiculously loud and clear, recreating high end frequencies for your audio stage with authority. These tweeters are sold as a pair and feature a max power rating of 500 watts.
www.skaraudio.com
Dayton Audio ST602-4 60W Titanium Bullet Tweeter with Square Frame Pair
Dayton Audio ST602-4 60W Titanium Bullet Tweeter with Square Frame PairDayton Audio ST602-4 60W Titanium Bullet Tweeter with Square Frame PairFantastic high-frequency performance, even better valueThe ST602-4 from Dayton Audio was designed to articulate and reinforce the high-frequency output of...
