I have the impression that live, the timbral differences between let's say Steinway, Bösendorfer and Yamaha are quite noticeable. When I've attended concerts or recitals with different brands I think I could tell the difference between them. And if you go to a piano store and try playing different models, they definitely sound different. This contrasts, and I agree, with the recordings, where it's almost impossible to tell the difference. Why is that?My guess is this is going to be a very similar situation to violins. There was that study that few, if any, could discern a difference between a cheap Yamaha violin versus a Stradivarius in double-blind tests. The most noticeable sound difference would be if strung with gut versus steel. But I won't digress into violins for this topic.
I assume that the biggest difference when judging the sound of a piano would be either the venue it is played in or the recording it's being played back from, depending on the method chosen. For the latter, mic and lid positioning will all have a factor on how a piano sounds in a recording. I tried years ago to double-blind via a program the differences in pianos between recordings and could not consistently tell the difference between a Bosendorfer against a Steinway. In fact, the only way I could notice a difference (and even that inconsistently) was if the recording was by Decca, due to a specific way they had recorded the pianos; the Bosendorfer gave off a very characteristic attack that was noticeable on these recordings.
I'd like to see some measurements of pipe organs.This tops all the requests I've seen.
Because a piano is the third-hardest thing in the world to record well. Ideally, for complete integration of all a piano's sound-producing mechanisms, you want to be about 20' to 30' away, with the instrument set on a reflective floor, in a pleasantly reflective space, all of which is fine for human ears, because the brain can make sense of it all.I have the impression that live, the timbral differences between let's say Steinway, Bösendorfer and Yamaha are quite noticeable. When I've attended concerts or recitals with different brands I think I could tell the difference between them. And if you go to a piano store and try playing different models, they definitely sound different. This contrasts, and I agree, with the recordings, where it's almost impossible to tell the difference. Why is that?
Agreed. I would like to add to that with Bell Tower Testing.I'd like to see some measurements of pipe organs.
If we're doing bells, we should also do cannons.Agreed. I would like to add to that with Bell Tower Testing.
Because this one sounds good, but the guy talks about it a bit too much in an "audiophile" manner to my taste:
But how would one get a piano on the klippel?
