- As for SPL levels, these are marketed as a near/mid-field speaker (recommended listening distance from 0.50 to 2.50 meters). At this distance, there is no real concern with dynamic range capability. From 76dB to 96dB at 1 meter the lower bass and midrange linearity decreases by about 1dB. Above this output level, though, you can expect more limiting of the speaker to protect it, especially in the bass region. A pair of speakers would put you at around 102dB with respectable linearity. However, as with nearly every other monitor type speaker I have reviewed thus far, the output isn’t there for farfield + high-output listening. In other words, don’t expect to use these as main speakers where you are sitting 12 feet away and wanting to listen at 90dB average. These are not designed for that and Kali’s suggested listening distance is backed up by this data.
From this review:
https://www.erinsaudiocorner.com/loudspeakers/kali_lp-6v2/ emphasis added
I see this kind of comment about limited volume from active speakers scattered around here and other review sites. Some around here were ready to lynch me for calling attention to this problem. In some cases relatively expensive actives like the smaller Genelec's are like this. Actives which are able to play loud are available at various price points but the low end is around $4k for a pair for the JBL 708P which doesn't have a superlative preference score. With today's cheap Class D amplifiers that leaves room for some decent passive towers like the Revel F206. As the prices go higher as with large Genelec and Neumann actives, so does the ability to put together a great system with passive speakers.
For me this answers the question about why passive speakers still exist. It is silly to say that the reason is audiophiles want to mix and match or that many actives don't go with home décor. The price to performance ratio is there for most. What I see is some around here have become mesmerized by preference scores to the extent that nothing else matters. Furthermore, they forget many speakers can show a large improvement through EQ while the actives already have the EQ built in.
Please direct all hate mail somewhere else.
I have to note, and disagree with, some of your more dramatic asides ("Some around here were ready to lynch me"; "some around here have become mesmerized by preference scores") - but I think you make a lot of good points here.
I absolutely agree that one can put together amp+EQ+passive speaker combos that equal or surpass active speakers that cost the same money or even more money.
I also agree that some actives are output/SPL-limited for far-field listening, and since that tends to be smaller units with less built-in amplification, that does tend to create a somewhat expensive price threshold for far-field actives capable of high SPL without significant limiting of one kind or another.
Finally, I think you make a good, sometimes-overlooked point about the aesthetics of active/powered speakers in living rooms and such: it's not (just) the speakers themselves. It's often the cabling: a power cord for each speaker, plus an interconnect from the source to each speaker and/or some kind of umbilical cord between the two speakers, and so on. And if you have Genelecs and want to keep GLM connected (to be able to turn them on and off remotely, for example - something a lot of folks will want for a far-field situation), then you've also got an ethernet cable running from the GLM module to one speaker, and another ethernet cable running from that speaker to the other one - all in addition to the power cords and digital or analogue interconnects.
All that said, I would make a couple of small qualifications to what you've written.
One reason smaller actives are SPL limited is because they often have fairly deep bass extension for their size. So yes, passives can be improved with outboard EQ while actives are already EQ'd - but good luck finding a pair of sub-$1500 passive stand mounts that don't need significant EQ to provide equivalent bass extension to a similar size, or even smaller, active - and if you boost a passive's bass like that, then it's going to have SPL limitations, distortion problems, and compression issues of its own. Erin provides compression graphs with most of his speaker reviews, and even just out of the box with no EQ, a lot of passives come with their own compression problems at higher SPLs. Actives might mute entirely because they have amps and electronics to go into protection, but if your passive compresses significantly, that's not really any better - the actives just give you a clearer sign than passives do that you're playing louder than the speaker can properly perform at.
So I think to really kick the crap out of actives price/value-wise, you have to go to passive floor-standers or a subwoofer, and there you're talking about extra expense compared to just a pair of very good stand mounts.
Finally, I feel like the whole SPL limitation issue, while real, is overblown, because a lot of the figures we see thrown around are for a single speaker. With a stereo pair, my understanding is that in-room SPL will be about 6dB higher, which is not insignificant given that a lot of the "seriously SPL limited" speakers we've seen around here can play close to or at the safe limit for hearing even just with one speaker.
