- Joined
- Sep 4, 2019
- Messages
- 1,172
- Likes
- 2,323
This is intended as somewhat of a fun exercise. I currently use a pair of Wireworld Oasis 8 (might be 7s) cables that I solder terminated with beryllium copper low mass BFA Z-plug bananas. Why the Wireworld. Well, I purchased 30 feet of it for about $80 off of a spool a few years ago. Why the z-plugs? They make a super tight connection (sometimes too tight) and were not bad to solder and then heat shrink and I paid about $25 for 20 of them. There is one issue with the cables, they are bright blue and I am trying to make my system a bit less intrusive and wife 2.0 happier with the living room so I don't have to go shopping for 3.0.
So I am looking at two different cable options. The first is the Blue Jeans Canare 4S11 biwired with bananas. I am attracted to these because Blue Jeans ultrasonically welds the cables, so no air to get in and corrode the connection. I am a bit picky about this, as the only speaker cable that I have ever had that made a difference in sound was one that was defectively soldered by the manufacture and corroded.
The second option I am looking at are Krux Kable Interlaced Braid 3d speaker wire, which is simply a Kimber Cable 8vs knock off. Their information is listed here:
http://www.knukonceptz.com/home-the...rlaced-braid-3d-copper-12-gauge-speaker-wire/
So here are my thoughts/questions:
1) Braided cables raise capacitance in exchange for lowering inductance. I know that this can cause some amplifiers to oscillate. I currently use a Sunfire Stereo amplifier (technically a Class H amplifier). If I ever replace it, it will be with a Hypex of Purifi. Speakers are either Magnepan 3.5s or Revel F208s. I don't believe I have any concerns here, anyone think otherwise?
2) If I get the Krux Kables, I will probably terminate them with Seawell Deadbolts, as they are fast and easy to use. I like the aesthetics of the Krux Kables. Long term, would you be concerned about cable oxidation since the connection is not gas tight?
3) Which would you pick? Why?
