What is the BEST amp below $200? and $150
HorizonsEdge
I do not know if the chips are the same as in excellent, but hard-to-find 40wpc Loxjie A30
If fact the DA-9 and the A30 use the same chip. The difference is that the DA-9 uses dual Infineon chips and the A30 a single. The Sabaj A20a uses the same board as the DA-9 and is made in the same factory. I strongly suggest reading the threads on this forum. Beyond the subjective claims a few QA issues have been discovered and acknowledged by the manufacturer.
ModDIY
The BT20A is based on the TPA3116 chips, which is significantly overtaken by the newer TPA3225X (2015 I believe). I have a box full of TPA3116, this is ok for a portable bluetooth device or garage. The TPA3255 is significantly above the level of distortion. As for the DA-9, it actually exceeds the budget announced in this thread. It is equipped with a new class D chip technology from Infineon. I have an amp with this chips at home, we are indeed at a much higher level than the TPA3116, a more lower distortion and much more musical.
raistlin65
Grand Rapids, MI
Since most modern Hi-Fi amplifiers should sound the same when used within their performance limits, I am curious about your basis for making an audiophile-type claim of a "huge improvement"?
The Fossi BTA10 version has some issues that could be audible in comparison to an accurate amp. For instance, check out the frequency response
https://www.audiosciencereview.com/...udio-bt10a-bluetooth-stereo-amp-review.10506/
Like @adamjohari I have the BTA20. While I have not DBT'd it, it does not seem to me to be audibly transparent.
And interesting that you linked to the DA-9 thread. Lots of subjective testimonials about how it sounds in that thread :)
ModDIY
No subjectivism here ... just compare the distortion rates, that's what I did.
DWPress
MI
It's been mentioned before earlier in the thread but an Icepower or Ncore amp would fit the bill for a pure power amp.
adamjohari
If only I could share the A B comparison between the BT20A and DA-9, you guys would buy the DA-9 in a heartbeat
spaggom
Hi guys... I would like to ask your opinion (based on experience) of the best dedicated amplifier below $200 and $150 range?
Thinking of getting Monitor Audio bronze 2 and cant afford a $400ish amp yet. So just to get me going, any recommendations at this price point?
Fosi Audio TDA7498E 2 Channel Stereo Audio Amplifier Receiver Mini Hi-Fi Class D Integrated Amp for Home Speakers 160W x 2​
Price:
Sale price$79.99Regular price$89.99
Willem
In my view there is a point below which you are no longer getting value for money. For me that point is represented by the Yamaha AS201. I think it is the cheapest good amplifier with enough output power for many situations.
HorizonsEdge
Is this not discontinued?
Dzhaughn
Price:
Why would anyone refer this to the Ayima A07? Phrase you answer in the form of "Look at the measurements here: ..."
I do like my A07.
