What does "fast" mean with regards to an amp?
Nozza
I was reading some reviews of old amps on What Hi Fi and they described a Cyrus on as "fast, articulate and agile". What does that mean exactly?
It implies that some element of timing is in play but surely with an analogue amp, the output signal is pretty much instantaneous to the input signal?
How would such things show up in measurements?
Or is it actually a pscyhoacoustic effect related to maybe the low frequencies that are used in the rhythm section of pop music - bass and drum kicks?
Or a load of waffle?...
Doodski
I think it is the reviewers imagination.
A decent amp operating within it's limits has good linearity in that the the input is similar to it's output. The better the amp the better the linearity and the better the accuracy and drive to the transducer.
I suspect some people focus on the mid bass, mids and think of speed and attack.
Most likely. :D
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Might be some version of impedance (damping) or slew rate (high frequency performance) commentaria.
highpurityusbcable
It's from an Audio Gear Review Generator. Creates an audiophile review with a couple of clicks using keywords like "fast, clean, warm, clinical, airy, holographic, neutral" etc.
I once visited a site of some reviewer where every single IEM set had an "agile bass".
Doodski
What HiFi commonly uses these sort of terms to describe their testing of various audio gear. It's gooblygook.
Examples from What HiFi webpage:
-Transparent across frequencies
-Expressive dynamics
-Full-bodied, detailed sound
-Powerful, agile bass
-Lively sound
-Even-handed, informative nature
-Sensational sense of timing
-Beautifully balanced
-Insightful sound
-Surefooted with rhythms
-Ace dynamics
-Good composure and insight
-Stunning resolution and agility
BDWoody
Chief Cat Herder
Moderator
I was trying to be generous.
mhardy6647
Well.
The speed of sound and the speed of light are both -- well, OK, within some constraints ;) -- constants.
I mean, 50 years ago, we were all into slew rate and TIM (transient intermodulation distortion) but that's not stuff you hear much about any more.
Draw your own conclusions.
TheWalkman
-Lively sound
-Insightful sound
-Ace dynamics
Versus, “The amp sounds great. The end.” This type of review isn’t particularly good for long term readership of a website or magazine.
solderdude
The Neitherlands
Has been discussed in this thread:
https://www.audiosciencereview.com/...lifier-speed-and-resolution-be-measured.5906/
ahofer
New York City
ahofer
New York City
Surely the speed of an amp depends on the height one drops it from.
But then you don’t know exactly where it is.
Phorize
U.K
In What Hifi it likely means ‘I like to receive advertising revenue from this manufacturer’ or ‘this amplifier class a/b is made by a small to medium size British manufacturer’.
Phorize
U.K
