I only fret over RCA interconnects.
Apologies for the long intro but this is my setup:
All sources are digital (media server, disc player, Apple device, DAC for TV and A/B comparison). Each has a single ended connection to my vintage NAD receiver, which also has an effects loop (tape monitor) for an EQ or tube buffer, plus a second tape in/out to audition new sources and feed an adjacent amp powering outdoor speakers. The NAD also connects to my TV antenna in the attic, and I use the "B" speakers to feed line level to a sub. Mounted under the media cabinet is a cable modem and a WiFi router (configured for max range) with ethernet ports. On top of the media cabinet are the bookshelf speakers, and immediately to the side is the sub. Everything is within 4 feet of one another.
To connect it all I have jammed in and around the media cabinet: eight pairs of RCA cables, ten power cables (factory), a USB for the DAC (factory), a toslink (2020's ETK), two coax (homemade RG-6), two pairs of indoor speaker cables (2000's Kimber Kable 4PR), one outdoor speaker cable (2020's high-purity oxygen-free copper 4-conductor for the long run), and three CAT 5E (entry-level Cable Matters). Until recently I relied on a rebadged Tripp-Lite consumer surge protector which didn't have enough sockets, so the sockets on the back of each amp were feeding multiple devices via splitter power adapters. The wiring in the house is old BX cable from the 1930s, terminating at cheap Leviton wall outlets. LOTS OF OPPORTUNITY FOR INTERFERENCE, AND NO FANCY CABLES.
RCA interconnects are a mix of 2000's Switchcraft (nickel jacks, tinned wires, very thin insulation), 1990's Radio Shack (gold or nickel jacks, copper wires, thick insulation) and 1960's unbranded (nickel jacks, unknown wires, thick insulation). Occasionally I encounter a cable that crackles when touched and I throw it out, otherwise they stay in the setup. It is a rats nest back there. I do my best to keep the cables organized but its hard to reach them. I have never de-oxidized the steel RCA jacks on the amps nor the nickel jacks on the cables, and some of them definitely need it.
With the above system and only the NAD powered, cranking the volume knob to 10 resulted in a whisper of white noise from the bookshelf speakers and a faint omni-present 60 Hz hum from the subwoofer. When playing music at moderate volume the sound is sweet, at loud volumes the NAD (2 x 35 watts) distorts but no one notices except me.
All was fine and dandy. I upgraded to a Furman PL-8C pro power conditioner (2 filter banks) and rearranged the power cables with a star ground . I noticed no difference in sound, but relieved to have good surge protection and connected equipment warranty.
I upgraded again to a Furman Prestige power factor conditioner (3 filter banks) dedicated to audio, a TrippLite ISOBAR (3 filter banks) dedicated to TV and internet (which improved stability of the internet service!), and replaced the wall outlet with an industrial Hubbell heavy bronze. The toroidal transformer in this new Furman hums quite noticeably (which I tested and confirmed is native to the unit), but now with only the NAD powered I can turn the volume knob to 10 and the bookshelf speakers are dead silent as if they are not powered.
The success of clean power vaporized tonight. I decided to turn on all my sources and play audio on them simultaneously. I then stepped through each input on the NAD, with the respective source paused, and cranked the volume knob to 10. EMI/RFI was noticeable on all inputs, most being very faint, except my media server (the most expensive component) crackled like a fire. I had never noticed this, and now realize the "warm" character it offers is actually EMI/RFI coloring the sound and also some of the distortion I hear at loud volume. Cutting power to everything else except it and the NAD did not help, and in fact some of the noise is native because putting the server's display to sleep reduced the problem. It also happens that the media server is tethered with an unnecessarily long interconnect that is subjectively crappy (lowest of the low budget Radio Shack).
Next step I will do some tests removing a few cables that I think may suck, and see if I can pinpoint the EMI/RFI leakage. Considering how it all is jammed tight, that step will probably prove a waste of time and I will choose to upgrade them all to well shielded budget interconnects ($10/each?), and possibly upgrade the CAT 5E cables. Though the EMI/RFI is not noticeable at moderate listening levels, the interference definitely degrades rendering of my audio by making my digital sources work harder.
I'll report back when I find a solution. My point in describing all of this is that if you have a densely laid out system, the shielding of your interconnects definitely matters. Its also worth noting that I achieved clean power in that dense environment without upgrading a single power cable.
