Wouldn't he do that so he could flog an 'upgrade kit' maybe?Also I think he was amongst the few (if not the only one) that gave the Lintons a bad review.
I know you know this, but for those who don't. Unfortunately to check the crossover components it would have to be fully dismantled. That might be an issue with a user submission.If you compare Amir's to the GR measures, you can find some similarities. but Danny's myopic scaling and over smoothing make this more difficult. His initial on-axis measure shows a major level matching issue with the tweeter (Amir's does not). In true Danny fashion, he does not question whether he has a broken/defective unit, he just proceeds with his upgrade. However, his initial crossover measure looks way worse than I would expect from Wharfedale and the Denton has a rather substantial crossover. He does not measure the crossover components, does he? I do not think have ever seen one of his videos where he does check the crossover parts. He simply skips a basic diagnostic step that any junior tech would do.
I'm sure he does want to sell an upgrade kit with those tube connectors. That said, whatever you feel about D, keep in mind that these are sent in by people who are commissioning him to upgrade the unit. So it is something he was tasked with doing.Wouldn't he do that so he could flog an 'upgrade kit' maybe?
The response issue exists with the individual RAW drivers mounted in cabinet(no crossover involved) drivers+cabinet only. Therefore I'm leaning into a possible well out of spec woofer. I would also find it had to imagine anything with the crossover increasing the effective woofer sensitivity and peaking by so much.
I wish he had published an impedance trace pre-mod, that could offer some clues.
So, it is certainly possible his was defective or at least using drivers(or x-over components)well out of tolerance. That said, to my eye his measured, completed speaker response tracks very well with the Klipple except the woofer is about 5db hotter relative across. All the other deviations match well. As a wanna be speaker designer myself, I don't mind his zoomed in scale as it illustrates the deviations well in the context of a teardown video. The 1/3 octave smoothing is okay but maybe he could use 1/6 or 1/12 to show a few more deviations up top. Really though 1/3 is fine for me for a basic investigation. Don't get me wrong, the Klippel is king and I appreciate the high resolution and high accuracy of that machine, it just isn't the minimum that provides value.
If anyone out there did this mod I'd be curious what your set measures like.
Often I pull drivers and photograph and measure raw drivers and the speakers to some degree or another for my hobby records. Unfortunately I did not do any of this with these. That said, I am pretty sure these are really, really, really cheap drivers. That can be fine as the sum of the parts is important, (think JBL 305/6p ----->those are some cheap drivers) but you also likely deal with a larger % of products and components not to spec.
Here are screen shots of Danny's Measurements so folks do not have to watch the whole video and be tempted to buy.
-------- View attachment 347105
View attachment 347096View attachment 347097
I felt the Linton had warm/maybe flabby fleshy bass. I did use the grills as the data recomended and still felt they sounded meh through the mids and treble. I didn't really love them though I always say 'I see the appeal'.
They are basically a decent $500, 5.25" 2way strapped to a serviceable 8" woofer tuned warm with a wide baffel that also warms up the sound in room compared to slim units. They look cool and they sound fine. I don't know? I think they were hyped a bit. I'd rather do something else, just my 2cents. If you own and love, totally get it.
Same as above, if anyone out there did this mod I'd be curious what your set measures like.
And a somewhat larger box, making it a completely different speaker from the 80th.@amirm
I have to add.....
Note that there is an "85th" anniversary version of the same speaker which uses a different tweeter. Wonder if every 5 years they are going to produce a different version!
80th anniversary has a 5" woofer
The 85th has a 6.5" woofer and a different tweeter.
I have zero experience with any Wharfedale speaker, but I've seen this phrase in lots of places and want to know what the heck does "fun to listen to" mean anyway? I've heard loads of speakers in my day and have never thought this about any of them. "Sounds good", "Sounds bad", well sure. Lots of music is "fun to listen to", but speakers???? Just don't get it...
"Fatiguing" is exactly the opposite of my opinion of the Denton 80.I had these briefly years ago because I wanted "warm" sound. I found them to be uneven and fatiguing. Seeing these measurements helps me understand now why I disliked them so much.
Exactly. Not ideal for critical listening. That's where the "fun" aspect comes in.Yes, I'm using this Denton 80th speakers in my office as decoration.
Not good for critical listening but playing bgm it's okay.
Here is PART of something the actual Designer, Peter Comeau said recently about measurements etc. There is far more, but this section addresses the topic of your post...Also I think he was amongst the few (if not the only one) that gave the Lintons a bad review.
That’s the heart of the problem.
One can rarely be certain whether the speakers used for the design study were correct or not, but in Danny’s case he has surely “upgraded” a fully defective pair of speakers in the past. In that situation and given the odd behavior of the drivers, one would normally search for other existing measurements. Then, he offered an expensive upgrade kit based on said defective speakers, using an incorrect measurement axis not originally intended by that design, crippling its original impulse alignment.
Howdy @beagleman see post #15 https://www.diyaudio.com/community/threads/wharfedale-linton-85-crossover-upgrade.407315/Here is PART of something the actual Designer, Peter Comeau said recently about measurements etc. There is far more, but this section addresses the idea of your post...
"Frequency response: Frequency response in axis at 1m doesn’t give you any clue as to how a speaker sounds. The ear/brain system is much more critical of temporal performance and whether the harmonic structure of an impulse is correct/realistic than it is of 3dB changes in frequency level. Also, how you make these measurements is critical. Making a gated response in-room, like GR Research, is prone to huge errors. Compare its results to the Stereophile and Erin’s Audio Corner reviews. Erin and Stereophile accord to the measurements I make as a designer. Nuff said."
I totally respect Amir's testing. I miss the test reports in the audio magazines of the past, from 'Stereo Review' to 'High Fidelity' to 'Audio' and, when I had access to them in the 80's, the British publications. I subscribed to 'Stereophile' for a year or two, and gave up after the nonsense about green magic markers for CD's and the magical RF-absorbing brick. I rarely looked at The Absolute Sound. I have my own listening preferences, and my positive opinion of the Denton 80's enjoyable sound hasn't changed.As someone who owns and loves the Denton 80's, I'm very surprised and disappointed with these results, and am now questioning my own ears and tastes...
That being said, I still love them, and they are my favorite speakers under $600 (that I have heard). I know this is anecdotal, but I've known a couple of people who've owned both the Lintons and the Denton 80's -- one of them sold their Dentons after getting the Lintons, and misses them dearly. The other actually preferred the Dentons to the Lintons, not because they were subjectively better, but because they were just "more fun to listen to."
Anyway, thank you Amir for the measurements/review! I'll keep at least one pair of the Dentons, but starting to look for a suitable replacement in my main listening room. Maybe the Ascend Acoustics Sierra-1 V2's?
You are allowed to have your own experiences and opinions, you know, regardless of what some numbers and graphs on the internet sayAs someone who owns and loves the Denton 80's, I'm very surprised and disappointed with these results, and am now questioning my own ears and tastes...
