- Joined
- May 4, 2022
- Messages
- 511
- Likes
- 561
To summarize, the discussion between antcollinet and myself began with the following post by me:
That understanding was reached by researching the subject and piecing together various pieces of information - this thread peaked my curiosity in this subject. Admittedly, this subject can be a little confusing, and it took careful reading and analysis of the various references to reach my understanding.
antcollinet replied with the following:
This appears to me to be the underlying issue in the back and forth discussion between antcollinet and myself, as well as the discussion between danadam and myself.
As noted, this subject can be confusing, and I understand why it can be hard to grasp. But, with further research I found the paper "Designing and Evaluating a Delta-Sigma DAC for Hi-Fi Audio" (https://liu.diva-portal.org/smash/get/diva2:1745070/FULLTEXT01.pdf). That paper ties everything together in a single reference, fully disclosing using dithering in an audio DAC to perform noise shaping in order to redistribute the quantization noise over a wider frequency spectrum, and then filtering out the higher inaudible frequencies. The result is a reduction in the quantization noise in the audible frequency band, performed by the DAC.
I understand that danadam performed an oversampling test with results that do not correlate to the above paper nor the other references I cited. danadam did not post which DAC and/or oversampling algorithm was used for the test. Based on the results, though, it appears that whatever algorithm was used for the test probably did not implement noise shaping as discussed in various references that were cited.
At this point in time I have nothing further to contribute to this subject.
My understanding is that the primary benefit of oversampling is to improve the effective SNR with respect to quantization noise. Specifically, dithering is used to redistribute the quantization noise over a wider frequency spectrum extending well above the audible frequency range, and then the higher inaudible frequencies are filtered out. The audible difference primarily is detectable in quiet passages where the music signal is low, for example a decaying piano tone. See, e.g., https://science-of-sound.net/2016/01/quantization-noise-and-bit-depth/
But that only works at the adc stage, or when downsampling. It is not (if I understand correctly) possible to shape the quantisation noise in an existing quantised signal by upsampling. It is already baked in.
