I recently bought a Audio Technica AT-LP120XBT-USB with a AT-VM95ML cartridge upgrade after a long time of wanting to play my record collection that I haven't listened to in 20+ years. My old Dual 505 is out of commission due to degraded belts and sticky mechanisms. This is a relatively simple repair that has been on my to-do list for years, but keeps getting pre-empted by higher priority tasks.
My major requirement was for a turntable that I could pull out and listen to 20, 30 years from now. A "forever" turntable in terms of reliability, if not sonic quality. That means no belts to degrade. No automatic mechanisms to get sticky and need cleaning and lubrication. So direct drive and manual operation were requirements.
Another factor for me is that I don't have a conventional stereo system any more. My stereos consist of self-powered speakers and a WiiM. I don't have a phono preamp and an integrated amplifier. I don't have a stereo rack to put those things in. I don't want a bunch of wires either. So built-in preamp and Bluetooth were requirement. A USB output was a nice-to-have feature in case I want a digital copy of a rare recording.
The AT-LP120XBT-USB was the best turntable I could find with direct drive, manual, and Bluetooth. That said, it is definitely not the greatest turntable. The specs are mediocre. (I do not find the noise level bothersome but I can hear the pitch instability). The body is plastic. It does not have good acoustic isolation, despite having a heavy steel plate inside to add mass and isolation feet. The tone arm does not have vertical tracking adjustments or azimuth adjustments (although the latter can be added by using a different headshell, and the former can be accomplished by changing mat thickness). The anti-skate is badly calibrated on my unit, and needs about 1/2 the suggested anti-tracking. The supplied AT-VM95E cartridge is OK but shows the same limitations that every bonded elliptical stylus does. And of course, audiophile purists will sneer at internal preamps and positively scorn Bluetooth.
None of that matters to me. The sound with the AT-VM95ML cartridge upgrade is delightful (that's one audio upgrade that produces obvious audible benefits for relatively little cost). The build quality isn't an issue - I listen near-field at modest levels so the acoustic pickup of the turntable isn't an issue, and the wireless connection allows me to place it across the room from the speakers. And most importantly, I am greatly enjoying my 500+ records that I haven't heard in decades, and rediscovering old favorites I had long forgotten. So, mission accomplished, and $570 very well spent!
