There is no standard gain - although gain in the region of 25 to 30dB is common. However the topping PA5 for example has a gain of only 20dB (x10)Hi all, I would like to have something cleared regarding gain and power.
I would like to know if there is a 'standard' gain that most amplifiers use.
Also I would like to know if the standard rule of 3db increase= double the power is valid when comparing different gains on the same amplifier or even different amplifiers: so an aplifier with 9db gain and 50w max power in 8ohms has the same spl of another amplifier with 12db gain and only 25w power into 8ohms?
Is the calculation a rough estimate or is it precise?
Thanks for any help on this.
Gain simply multiplies the input voltage to output voltage.
It doesn't alter the maximum power or SPL of an amplifier. It only changes the input voltage needed to achieve the maximum power/SPL. The maximum power is limited by the output voltage or output current limits of the amp - not by the gain.
A very high power amp might need to have a higher gain in order to allow lower voltage sources to drive it to full power.
So for example if you have an amp with a gain of 26dB (x20) which is capable of 300w into 8 ohm (needing 48V), then a 2V (typical RCA) source would only be able to drive 40V to the output of the amp - which is only 200W into 8ohm. For this source you would need a gain of at least x25 (28dB) to drive it to full power. Or you would need a source capable of higher voltage.
