no like, if I tap on it there's a faint metallic sound, not through the headphones, it's like a spring moving inside, it seems to work fine thoughWas there any hum ? Rattle and hum ? (sorry )
I got mine today, cost me nothing to get a new one, big credit to Topping
Everything sounds perfect.
Does the gain knob (I guess that's not the correct word, but the one I can change between -9, 0, +9) do any changes in the sound, I think the volume are to low with -9db.
I would like to share my positive experience so far with Apos regarding the L30 exchange program. I asked whether they will be supportive, and they assured me they will. Apos later sent me the email quoted in part below and another with the order number for my replacement L30.
While I do not yet have a replacement in hand, the communication from Apos has been encouraging. I expect to remain a customer of both Topping and Apos.
https://www.audiosciencereview.com/...-headphone-amplifier-review.15226/post-652068Everyone happy BUT, how can you know if your 2012xxxxxx is on of the many in the 90% or one of the few in that 10%?
4 screws at totalAnybody willing to open up the backplate of the 2012 L30 so one can easily check if they have the ESD fix.
It is just 2 screws on the rear and the packplate comes off.
You only have to unscrew the two screws mentioned by solderdude to remove the backplate.4 screws at total
2 more at the RCAs connectors
I think it's the same.Anyhow is it just me, or do i get a sense that it's a bit louder than previous versions?
