hmmm acc. to the rules that original amp should have been disposed of.
Besides when it is faulty it wouldn't work. I suspect you mean it is a still operational pre-2012 L30.
Yes it is operational pre 2012 L30... i used the wrong word , sorry .
Guess that would be possible but you will still have two separate volume control/knobs per channel which could be a pain to manage. Any reason you must have balanced btw? Will simply make things louder, besides that there's no real game changer there.Completely out of the theme. I don't know of I'm gonna be able to explain it right because my english... Is it a bad idea to feed a L30 with a balanced signal splitting the positive to one channel (eg. left side) and negative to other (right side) and than uses it to feed just one driver (>=32ohm). The male TRS shall be soldered as balanced connection: tip = positive, ring = negative and sleeve = NC (in this specific case). The idea is to use L30 as bridge/balanced amplifier. For it would be necessary two units... A cheaper way to "simulate" the A90 balanced output :v
I think this idea was already posited when the JDS Atom came out, but not sure anyone actually tried it.. In any case, 'dual' SE amp this way will likely work but I'm not sure it is really all that ideal for a HE-6. In fact, maybe it would be cheaper to just get a budget speaker amp and interface the HE-6 to the speaker outputs ? Just an idea.You are right. I don't mind balanced output, L30 at mid gain is completely fine with a HD650. But this idea is to drive a Hifiman HE-6 (not mine), this hp is an example of ineffectiveness.
About the volume it would be controlled digitally leaving the potentiometer at max all time.
Yes, you are right, thank you! It's no more in use. I will try to exchange it for a modified one.You would be wise to exchange it for the serial number alone.
Sounds a bit like a damaged OPA (could be static discharge) so would recommend to NOT use it again, contact your seller and ask to have a new one sent. I am quite sure your serial number starts with a number below 2012.
Should definitely be possible and not a bad idea. Might still not reach ear piercing volumes though.Is it possible and if it is, advisable to run the L30 in preamp mode into the A50s to power a pair of HE6?
Ah okay. Surprisingly I am able to get to a listenable volume on the A50s on low gain BAL out at around 2 o’clock on the HE6. Just wondering if the extra power would make any differenceShould definitely be possible and not a bad idea. Might still not reach ear piercing volumes though.
It's just a click away to listen to the higher gain and hear for yourselfAh okay. Surprisingly I am able to get to a listenable volume on the A50s on low gain BAL out at around 2 o’clock on the HE6. Just wondering if the extra power would make any difference
Well one person's ear piercing is not another's I suppose, Amirm got the HE6 to distort on a Topping A90, I don't even want to know how loud that must have been..Ah okay. Surprisingly I am able to get to a listenable volume on the A50s on low gain BAL out at around 2 o’clock on the HE6. Just wondering if the extra power would make any difference
Just got my E30+L30 stack, funnily enough the E30 is 2101xxx and the L30 is 20126xxx, unlucky I guess! I didn't unscrew the backplate or measure it, but there is a bit of that pogo action and it clicks a bit at the back so I assume the pin is in there. The volume pot is indeed a little bit weird, that's kind of disappointing. Sounds fantastic though, 0dB gain around 1-2 o'clock with the K712 is the farthest I'd go in terms of volume (and I'm doing a -4dB pregain in EQ APO as well)
Which set did you use before, the sound quality has improved very clearly with the e30 + l30?
Before i buy i confirmed it is 2101xxx or higher for l30 then i bought it.
