There's a thread for amp sniffingDid anyone else get an L30 with plug that smells quite bad of chemicals? I've had it airing out for days and it doesn't seem to be getting much better. Also when it's plugged in it seems the heat makes it smell more.
Do we have any evidence this is what's killing L30s? Or is this the current best guess?Static electricity discharge (ESD) can render the L30 useless in select few instances.
That was my recap of what was being presented a few pages back. At best it’s been guessed by couple other people that it may be ESD, no forensic or actual proof or disclosure from Topping at this pointDo we have and evidence this is what's killing L30s? Or is this the current best guess?
I'm unsure about how the anodized aluminum case effects ESD. It's obviously not grounded.
https://www.audiosciencereview.com/forum/index.php?threads/noob-amp-smelling.18087/unread
Asr Catering to all audio fetishes
Had it plugged up for months don't smell a thing,bought It the day Apos Audio sold it.
Sort of. For me the reasons for external PSUs have been known for a long time. Given the video title I thought it would explain them in detail, and of course I didn't watch it because I thought it'd say things that would be useless for me. I was in a rush, and my point was just to prove that in 30 seconds I could find material on external PSUs assets. Unfortunately it was clickbait. Had I spent more time I would have found better material. Here's something better : https://www.electronicdesign.com/po...e/21808839/3-ways-to-reduce-powersupply-noise .So you shared a video with us that you knew to be "useless" as proof that we should debate this issue?
Then by all means, don't. Waste of time for both of us.I'm never interested in having a discussion with someone who grabs the first thing they can find off the internet as evidence of something, even though they know it's a terrible source.
May be a failed unit.@JohnYang1997 Can you tell if the L30 has any plug/unplug TRS connector sensor? These days I've being experiencing a few cut outs from right side. I'm not sure, but I may have isolated the problem to TRS connector. The cut out is "solved" after a few plug unplug cicles with the headphone 's jack - does not matter the headphone, DAC or cables - I have tried different cables, DACs and cables.
Just ask your seller and they will help you out.Meeh fork. I will try it out a few more days. I have this unit since october and no problem until this... How should I proceed if occurs that it be a faulty unit?
Just in case ESD is a problem. Is there any precaution I can take to avoid it?
Just in case ESD is a problem. Is there any precaution I can take to avoid it? Discharge myself on the E30 before touching the L30? (E30 should be grounded via the USB connector, right?_
Also how does ESD get inside the L30? Via headphone connector, volume knob, or chassis?
Grounding yourself before touching the L30 should prevent this.
For my job I have to test designs for EMC and ESD.
They 'fire', with a device that actually looks like a gun, on every part of the design that can be touched by hands as well as on inputs and outputs.
In these systems there were also PC's.
One day the system had passed all tests (including the ones that are potentially destructive which is done at the end) and shooting at all points of the PC worked fine. Then the tester decided to shoot at the front of the enclosure at a mechanical lock that holds down a lid and the PC crashed.
It was a grounded lid on a grounded enclosure with no electronic parts inside.
We thought it was a coincidence so after rebooting we tried again. Same happens.
Just a shot at a mechanical and safety grounded part of the enclosure locked up the OS.
The thing with ESD is that the frequency component is very high and can cause a high 'peak' somewhere on the PCB.
Very hard to determine what that path is.
For me the solution was simple. We mounted a wristband to the frame and an instruction on the cabinet to wear the antistatic wristband when servicing the equipment.
I can see the short term Topping fix now. Free ESD wristband with every order.
