Hmhhhhmmmm... I'd really like to buy one but one the other hand I'd like DAC & amp combo. I wonder if Topping has plans for DX4 Pro or something that would basically be E30 and L30 in one box. That would be very convenient.
I have searched all posts on this thread for "DSD" in order to determine whether this unit as currently shipped can handle DSD64, and I have not been able to make that determination. If I ordered an E30 today, would it be able to effectively play DSD64 streams?
I used to have the d50s as well. E30 just arrived after 17 days. I'll let you know.this guy describes the topping e30 as more spacious sounding and better clarity than the d50s... any thoughts.?
from 7:40 to 9:00
from 7:40 to 9:00
The E30 that is currently on the market has improved firmware, and I don't think there is a problem with DSD64.I have searched all posts on this thread for "DSD" in order to determine whether this unit as currently shipped can handle DSD64, and I have not been able to make that determination. If I ordered an E30 today, would it be able to effectively play DSD64 streams?
I went through my DSD64 files to E30 without any problem, and it sounds well.The E30 that is currently on the market has improved firmware, and I don't think there is a problem with DSD64.
That is just swellI went through my DSD64 files to E30 without any problem, and it sounds well.
That is just swell
For sure...that's why it's a good sellIs it as clear as a bell?
I feel as though I'm under a spellI like it with Adele.
laughed out loud
If one order now through Audiophonics.fr it will arrive in Europe in 15 to 25 days, so most likely it will be new production units, with the firmware problema solved.The E30 that is currently on the market has improved firmware, and I don't think there is a problem with DSD64.
Hi everyone,
I'm new to this forum, but was following already for quite a while. This forum and thread helped a lot with my decision to buy the E30, which I received a couple of weeks ago
I am quite happy with it so far, but there's one little problem which is a bit annoying.
Sometimes there is no audio output, after E30 turned itself on after standby. It's showing the correct input channel, no error displayed, but no output. Only when I switch the E30 off and on again via the remote, sound will play. I have installed the device driver as well as updated to the latest firmware, but the problem also was happening already before.
I am using Windows 10 and the E30 is connected by USB.
Has anyone else experienced such a problem?
