I think he was postulating that the feature could be modified to do so via a firmware update if the engineering effort was performed. Not that it was included in the version posted on toppings website. While possible I don't see it happening, there's nothing defective with it's operation, rather just not the behavior some expect.
Indeed. Since there is no on/off switch, I do
"expect" the unit to go into standby mode when there's no music playing. It's not a huge problem that it
doesn't; merely an annoyance.
I did a little more experimenting (which involved sacrificing a USB cable). 0V on the power pin is
not the signal for the E30 to go to sleep. But +5V on the power pin
is the signal for it to wake up. So, as long as the USB port is powered, the E30 will not
stay in Standby mode (even if you manually put it there).
