Topping DX7 Pro DAC and Headphone Amp Reviewed
I thought Topping would fix the output impedance of the headphone jack to make it a perfect an all-in-one state-of-the-art DAC/headphone amp solution. Too bad it is still not there.
I think they would have if people had not complained so much about the original DX3 Pro.
Ok, I see, really hard to use my balanced 50 Ohm planars in such case...
If their impedance is flat with respect to frequency as it should be, it won't be an issue.
mi-fu
New York
Amir, do you have any idea or guess why the original low output impedance of the 1st version DX3 Pro is related to the stability issue?
I think in some cases it would short out so they now put resistors in the output to avoid the amp seeing such a low load.
MediumRare
Chicago
So, with 114 impedance and a flat WRT frequency I shouldn't have any problem? Said another, will it be exceptionally good? ;)
gvl
SoCal
I kind of wish they skipped the mediocre built-in headphone amp and kept the price lower. What's the point to bundle a SOTA DAC with a just "okay" amp and force the people to pay for the feature they will likely never use?
Mr. Olinad
Guarulhos - SP
Thanks for your work @amirm
As an owner of a Sabaj D5 I was waiting for this review to see if it worth the extra $200.
Is it possible to have the Sabaj D5 on your Headphone Amplifier 50 mv SNR graphic?
JohnYang1997
China
Because adding headphone amp in an existing enclosure is cheap and efficient. And it's adequate for most people if not all.
Also that's what the DX series is right? D series should have no headphone out.
MediumRare
Chicago
Trying to understand the absolute quality of the headphone amp section. If I understand correctly, SNR @ 50 mV is the key real-world measure, i.e., where we will be listening to actual music. With that measure, the DX7 Pro is about 80.6, at the margin of tier 1 and tier 2 https://www.audiosciencereview.com/...asurement-comparison-charts.8246/#post-207213
So, my questions:
1. Did I get that right? If not, pls point me in a better direction on how to compare to the SOTA and is any difference at this level of excellence audible?
2. Will balanced output make any difference? (perhaps 2-3 dB better?)
JohnYang1997
China
So, my questions:
Balance will make it worse because there is no attenuation for noise so you end up with sqrt 2 times the noise with when volune kept the same.
Very sensitive iems will make the noise audible. Only at the level of rme you can't hear the noise. Below that you may hear with some iems.
No. That is the level you may use with a very sensitive IEM. That is the only time that measurement matters.
MediumRare
Chicago
Hmmm, I'm looking at the THD+N% v Power graph and at every point the SINAD is a little better with Balanced, so what am I missing?
