• WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). Come here to have fun, be ready to be teased and not take online life too seriously. We now measure and review equipment for free! Click here for details.
Master Index of Measurement Comparison Charts
pozz
Contributor
Patreon Donor
Editor
#1
Below is a list of links to comparison charts for the major types of hardware reviewed, measured and tested on ASR. They will be updated as more reviews are done.
As always, please message me if you catch errors.
Audio Analyzer Charts
ADC/DAC Charts
Power Amp Charts
Headphone Amp Charts
Phono Preamp Charts
Portable DAC/Headphone Amp Charts
A few notes:
  • APx555 measurements are not static like they appear in the screenshots. There is a certain amount of variation in the results. As such, the values in the charts below are rounded to the nearest dB. The hidden decimal values are used for ranking only.
  • For each chart I've calculated a geometric mean for the dataset, which is a type of average that compensates for skewing due to values which are either very large or very small relative to the set. I've also calculated the absolute deviation from the geomean ("GMAD"). It's an indication of variance, i.e., of how far on average the measured values are from the geomean in either a positive or negative direction.
  • I'm still updating the charts and providing ranked links to reviews according to @digicidal's idea. 3/22 complete.
Descriptions of chart legends are included in the expandable notes below.
SINAD
  1. >120dB (>20 bits): Provably inaudible noise and distortion.
  2. 109dB—119dB (18 bits—20 bits): Well beyond 16-bit (CD) resolution.
  3. 96dB—108dB (16 bits—18 bits): Meets and exceeds 16-bit (CD) resolution.
  4. 85dB—95dB (14.3 bits—16 bits): Does not meet 16-bit (CD) resolution.
  5. <85dB (<14.3 bits): Performance is below the minimum lenient threshold defined in this thread.
  • SINAD results are presented after averaging the R&L channels. The bandwidth is 20Hz—20kHz.
  • Since performance is physically limited by the noise and distortion of the engineered circuit, the unique limits of each piece of tested hardware can be assessed using the SINAD ratio, which represents the noise and distortion-free operating range in dB.
  • SINAD is equivalent to both SFDR and THD+N, though the latter is in percent:
    • 0dB SINAD = 100% THD+N
    • 20dB SINAD = 10% THD+N
    • 40dB SINAD = 1% THD+N
    • 60dB SINAD = 0.1% THD+N
    • 80dB SINAD = 0.01% THD+N
    • 100dB SINAD = 0.001% THD+N
    • 120dB SINAD = 0.0001% THD+N
  • One of the simplest ways to gauge SINAD is to compare it to 16-bit CD dynamic range. 1 bit equals 6.02dB, making the maximum dynamic range of CDs 96.3dB (this is without considering the effects of noise-shaping dither in the digital mastering process, which typically detracts 3dB). This means that playback equipment should be capable of a SINAD of at least 96.3dB to ensure that all information of the encoded audio signal is reproduced in its entirety.
    • For perspective, the highest measured SINAD value is approximately 123dB (20.4 bits) for the Audio Precision APx555 analyzer.
  • It's also useful to consider SINAD values in terms of dBFS. 0dBFS references the maximum output of a digital signal without clipping. -120dBFS is provably inaudible even without taking into account psychoacoustic masking or equal loudness curves. Research by Louis Fielder from 1981 and 1995 supports this claim.
  • Thanks to @martijn86, @Matias and everyone else who participated in the thread which decided this approach.
SNR
  1. 76%—100%: Tier 1 (Best)
  2. 51%—75%: Tier 2
  3. 26%—50%: Tier 3
  4. <25%: Tier 4 (Worst)
  • SNR results are presented averaging the R&L channels. The bandwidth is 20Hz—20kHz.
  • The SNR ratio expresses the difference in power between a reference signal and the noise floor of the device. It does not take into account distortion (i.e., the amplitude of spurious tones adjacent to the main signal when plotted in an analyzer's FFT). While the noise floor may stay relatively stable, distortion is sure to rise as output increases.
  • The SNR value as presented in this thread's charts is calibrated to a very low voltage (50 millivolts) to approximate IEM sensitivity.
  • SNR unfortunately cannot be ranked in the same way as SINAD since it less clearly correlates to ideal performance. The measurement results are therefore organized by quartiles, with blue representing the highest tier of measured performance and red, worst.
Max Power
  2. 51%—75%: Tier 2
  3. 26%—50%: Tier 3
  • Continuous power measurements are made by driving both R&L channels and recording the result before the onset of clipping. This means that the results will reflect very different distortion levels.
  • The adequacy of an amplifier's maximum continuous power is highly dependent on whether it drives speakers or headphones, their sensitivity, power requirements and the application, such as whether you are using them at home or a studio, how loud you will play them and, for speakers, the size of the space you want to fill.
  • As such, measurement results are organized by quartiles, with blue representing the highest tier of measured performance and red, worst.
Headphone Amplifier Output Impedance
  1. <1Ω: Excellent
  2. 1Ω—3Ω: Good
  3. 3Ω—10Ω: Fair
  4. >10Ω: Poor
  • Output impedance is calculated after measuring the difference in output voltage between an open circuit and a loaded circuit, the load being 33.1Ω.
  • Output impedance can be ranked by measured value due to its relationship to frequency response.
  • Impedance varies with frequency and is a physical characteristic of headphone and amplifier construction. A loose rule is that the output impedance of the source (i.e., headphone amp) should be about 8 times less than the input impedance of the load (i.e., the headphones) to avoid frequency response changes. Common headphone nominal impedances are 33Ω, 300Ω and 600Ω, although IEM impedances may be lower, such as 8Ω—16Ω.
Finally, please don’t take the measured values too seriously. It should also be clear that these comparison charts are more for convenience and should not serve as a buyer's guide. As @amirm and others have shown in reviews and discussions, there is no obvious correlation between price and performance in general, or SINAD and price in particular.
For a full list of reviews, please see the Master Index of Audio Hardware Reviews.
pozz
Contributor
Patreon Donor
Editor
#2
Comparison of DAC SINAD Measurements
Number of Entries: 203
Date Updated: 16 September 2019
Links
121.………………………………Matrix Audio X-SABRE Pro
120.………………………………Matrix Audio Element X
119.………………………………Sabaj D5 (XLR Out)
118.………………………………Okto Research DAC8
116.………………………………Sabaj D5 (RCA Out)
115.………………………………Oppo UDP-205 (XLR Out)
115.………………………………Gustard DAC-X26
114.………………………………Oppo UDP-205 (RCA Out)
114.………………………………Chord Qutest
114.………………………………Exasound E32
113.………………………………Auralic Vega DAC
113.………………………………SMSL VMV D1 (XLR Out)
112.………………………………Benchmark DAC3 DX
112.………………………………SMSL VMV D1 (RCA Out)
112.………………………………RME ADI-2 (XLR Out)
112.………………………………RME ADI-2 (RCA Out)
112.………………………………Yulong DA10 SE
111.………………………………March Audio DAC1
111.………………………………Topping D50s
111.………………………………Aune X1S
111.………………………………Digital Amplifier Company DAC 1 HS
111.………………………………miniDSP SHD
111.………………………………Loxjie D10
110.………………………………Linn Akurate DSM
110.………………………………Grace Design m900
110.………………………………Geshelli ENOG2 Pro (RCA Out)
110.………………………………Orchard Audio Apple Pi & Volume+Clocker
110.………………………………Aurender A10
110.………………………………E1DA 9038S
110.………………………………SMSL SU-8 V2 (XLR Out)
110.………………………………SMSL SU-8 V2 (RCA Out)
110.………………………………Topping D70 (XLR Out)
110.………………………………LG G7 ThinQ (Quad DAC)
109.………………………………WesionTEK Khadas Tone Board
109.………………………………Chord 2Qute
109.………………………………Oppo HA-1 (Fixed Output)
109.………………………………Allo Katana
109.………………………………JDS Labs EL DAC (S/PDIF In)
109.………………………………Topping D50
109.………………………………Topping D70 (RCA Out)
108.………………………………NAD M51 (HDMI In, XLR Out)
108.………………………………NAD M51 (USB In, XLR Out)
108.………………………………Topping DX7s
108.………………………………Orchard Audio Apple Pi DAC
108.………………………………Creative SoundBlasterX G6 (TOSLINK In)
108.………………………………Musiland MU2 Plus
107.………………………………Geshelli ENOG2 Pro (XLR Out)
107.………………………………Audiophonics I-Sabre (ES9038Q2M)
107.………………………………Holo Audio Cyan DSD (XLR Out, DSD64)
107.………………………………Schiit Modi 3 (USB In)
107.………………………………Mytek Stereo 192 DSD (XLR Out)
107.………………………………Monoprice Monolith THX AAA DAC (Desktop)
106.………………………………Topping A30
106.………………………………xDuoo TA-10
106.………………………………SMSL Sanskrit 10th (External Power)
106.………………………………Creative SoundBlasterX G6 (USB In)
106.………………………………LG G5 Hi-Fi Plus
106.………………………………Topping DX3Pro
106.………………………………JDS Labs EL DAC (USB In)
106.………………………………ZorLoo ZuperDAC-S
105.………………………………NuPrime uDSD (RCA Out, Min. Volume)
105.………………………………NAD M51 (RCA Out)
105.………………………………Cowon Plenue 2
105.………………………………Topping D10
105.………………………………Apogee Groove
105.………………………………Benchmark DAC1 USB
105.………………………………Monoprice Monolith THX AAA DAC (Portable)
105.………………………………Schiit Modi 3 (S/PDIF In)
105.………………………………Musical Fidelity V90
105.………………………………Lynx Hilo
105.………………………………LG G7 ThinQ (Standard DAC)
104.………………………………Orchard Audio Gala
104.………………………………Topping D30
104.………………………………Topping NX4 DSD
104.………………………………Mytek Stereo 192 DSD (RCA Out)
103.………………………………Gustard A20H
103.………………………………Holo Audio Cyan DSD (XLR Out)
102.………………………………Massdrop Grace Design Balanced DAC
102.………………………………SMSL M100
102.………………………………Spectra X
102.………………………………SMSL SU-8 V1 (RCA Out)
102.………………………………Asus Xonar U7 Mk2
102.………………………………NuForce DAC80
102.………………………………Asus STX II
101.………………………………SMSL Sanskrit 10th (S/PDIF In)
101.………………………………Chord Mojo
101.………………………………Holo Audio Cyan DSD (RCA Out)
101.………………………………iBasso DX120
101.………………………………Melokin DA9.1 (Min. Headphone Volume)
99.………………………………..Cambridge DacMagic Plus
99.………………………………..Essence HDACC II-4K
99.………………………………..Apple Dongle
98.………………………………..iBasso DX120
98.………………………………..Schiit Magni 3
98.………………………………..Oppo HA-2 SE
98.………………………………..FX-Audio DAC-X7
97.………………………………..Massdrop Grace Design SDAC
97.………………………………..Pioneer VSX-LX504 (S/PDIF In)
96.………………………………..KORG DS-DAC-100
96.………………………………..Audioengine D3
96.………………………………..NAD M17 V2
96.………………………………..Schiit Jotunheim (AK4490) (XLR Out)
96.………………………………..Anthem MRX 520
96.………………………………..Gigabyte Gaming B8
96.………………………………..Schiit Jotunheim (AK4490) (RCA Out)
96.………………………………..Pioneer SC-61
95.………………..………………Pioneer VSX-LX504 (HDMI In)
95.………………..………………Schiit Bifrost (AK4490)
95.…………………..……………SMSL M10 (XLR Out)
95.……………………..…………Lyngdorf TDAI-3400 (RCA Out)
95.………………………..………JDS Labs The Element
94.…………………………..……SMSL M10 (RCA Out)
94.………………………………..Oppo HA-1 (Variable Output)
94.……………………………..…Lyngdorf TDAI-3400 (XLR Out)
93.…..……………………………Musiland MU1
93.……..…………………………Audirect Beam
93.………..………………………Parasound Zdac V2
93.…………..……………………iFi iDSD Black
93.……………..…………………iFi Nano iDSD Black
93.………………..………………Allo Boss V1.2 Raspberry Pi
93.…………………..……………HiFiBerry DAC+ Pro (RCA Out)
92.……………………..…………Fostex HP-A3 (TOSLINK In)
92.………………………..………Marantz AV8805 (HDMI In)
92.…………………………..……Paradigm PW-Link
92.……………………………..…HTC Dongle
92.………………………………..HiFiBerry DAC+ Pro (XLR Out)
92...………………………………Sonos Connect
92.…..……………………………Chord Chordette
92.……..…………………………Fiio K3
92.………..………………………Yamaha WXA-50
91.…………..……………………Marantz AV8805 (XLR Out)
91.……………..…………………iFi Nano iONE
91.………………..………………Chromecast
91.…………………..……………Matrix Audio HPA-3U
91.……………………..…………Audeze Deckard
91.………………………..………Sabaj Da3
91.…………………………..……HIDIZS Sonata HD Mk2
90.……………………………..…LH Labs Go2Pro Infinity
90.………………………………..Creative SoundBlaster X-FI HD
90.…..……………………………Sony PHA-1
90.……..…………………………SMSL iDEA
90.………..………………………Sony RSX-GS9
90.…………..……………………Sony STR-ZA1100ES
90.……………..…………………Wyred4Sound DAC-2v2 SE
89.………………..………………Google Dongle V1
89.…………………..……………Samsung S8+
89.…………………..……………NAD T758 V3 (S/PDIF In)
89.……………………..…………FiiO Q1 Mk2
88.………………………..………Sony UDA-1 (Min. Volume)
88.…………………………..……AudioQuest Dragonfly Red
88.……………………………..…CEntrance DACPort HD
88.…..……………………………Bluesound NODE 2i (Roon Stream)
87.……..…………………………Peachtree novaPre
87.………..………………………SMSL SU-8 V1 (XLR Out)
87.…………..……………………HP Z-14
87.……………..…………………Amazon Link Amp
86.………………..………………Pi 2 Design 502DAC
86.…………………..……………Schiit Yggdrasil V2
86.……………………..…………PiFi DAC+ V2
86.………………………..………Google Dongle V2
85.…………………………..……Teac HA-P50
85.……………………………..…Marantz HD-AMP1
85.………………………………..Soekris dac1421
84.…..……………………………Totaldac d1-six
84.……..…………………………Schiit Jotunheim Multibit
84.………..………………………ENCORE mDSD
84.…………..……………………Audio-gd DAC-19
84.……………..…………………Sony HAP-S1
83.………………..………………PS Audio Sprout100
83.…………………..……………Topping MX3
83.……………………..…………Acoustic Power Labs APL1
83.………………………..………BSS BLU-BIB & BLU-BOB1
83.…………………………..……LOXJIE d20
82.……………………………..…Schiit Modi 2 Multibit (USB In)
82.………………………………..Schiit Modi 2 Multibit (S/PDIF In)
81.……..…………………………Nobsound NS-DAC3 Pro
81.………..………………………SMSL AD18
80.…………..……………………SMSL Sanskrit 10th (USB Power)
80.……………..…………………Aoide DAC II
78.………………..………………ELE EL-D02
78.…………………..……………Breeze Audio ES9018K2M
78.……………………..…………ENCORE mDAC
77.………………………..………Klipsch PowerGate
76.…………………………..……Micca OriGen G2 (USB In)
76.……………………………..…Cyrus soundKey
76.………………………………..Audio-gd NFB-2
74.…………..……………………Micca OriGen G2 (TOSLINK In)
74.……………..…………………SMAKN X5
74.………………..………………Pioneer VSX-LX303
73.…………………..……………Venture Electronics (Veclan) Odyssey HD
72.……………………..…………C-Media CM108
73.………………………..………AudioQuest Dragonfly Black
70.…………………………..……Hifime UDA38Pro
68.……………………………..…Ayre CODEX (XLR Out)
68.………………………………..Ayre CODEX (RCA Out)
67.………..………………………Bluesound NODE 2i (S/PDIF In)
65.…………..……………………Audio-gd R2R-11
61.……………..…………………Woo Audio WA7 & WA7tp
59.………………..………………NAD 7050
55.…………………..……………Audio-gd NFB-28.28 (Fixed Output, XLR Out)
54.……………………..…………Fostex HP-A3 (USB In)
52...………………………………Bluesound NODE 2i (TOSLINK In)
pozz
Contributor
Patreon Donor
Editor
#4
Comparison of Power Amplifier SINAD (5W, 4Ω) Measurements
Number of Entries: 41
Date Updated: 16 August 2019
Links
113.………………………………Benchmark AHB2
108.………………………………Purifi 1ET400A (No Pre-Gain)
105.………………………………Hypex NC400
104.………………………………Purifi 1ET400A
100.………………………………Neurochrome Modulus-286
96.……………………..…………Nord One Hypex NC500
94.……………………..…………Accuphase E-270
92.……………………..…………Sonos Amp (Roon Stream)
90.……………………..…………NAD C 320BEE
90.……………………..…………Yamaha WXA-50
89.……………………..…………NAD 7050
88.……………………..…………Denon PMA-50 (USB In)
87.……………………..…………Sony STR-ZA1100ES (Direct Mode)
86.……………………..…………Teac AX-501
84.……………………..…………Denon PMA-50 (RCA In)
84.……………………..…………Amazon Link Amp (S/PDIF In)
83.……………………..…………Amazon Link Amp (RCA In)
82.……………………..…………Onkyo M-282
80.……………………..…………Class D Audio CDA-250C
80.……………………..…………Sony STR-ZA1100ES
79.……………………..…………Denon AVR-4306 (CD Direct Mode)
77.……………………..…………FX-Audio FX502SPro
76.……………………..…………PS Audio Sprout100
76.……………………..…………Crown XLS 1502
75.……………………..…………QSC DCA2422
75.……………………..…………Dayton Audio APA 150
73.……………………..…………IRS2092 IRAUD350
72.……………………..…………Sony HAP-S1
71.……………………..…………Paradigm PW Amp
70.……………………..…………Topping TP60
69.……………………..…………Sonos Amp (RCA In)
69.……………………..…………Pioneer VSX-LX303
68.……………………..…………Optoma NuForce STA-200
68.……………………..…………Topping MX3
68.……………………..…………Sony UDA-1
67.……………………..…………Behringer A500
63.……………………..…………Dual AM505BT
62.……………………..…………Sony MEX-XB120BT
59.……………………..…………Dynaco ST 70 Mk3
57.……………………..…………SMSL AD18
50.……………………..…………Monoprice Hybrid Tube Amp
pozz
Contributor
Patreon Donor
Editor
#5
Comparison of Power Amplifier Max Power (8Ω) Measurements
Number of Entries: 8
Date Updated: 17 August 2019
Links
369.……………………..….……QSC DCA2422
269.……………………..…….…Nord One Hypex NC500
138.……………………..……….Pioneer VSX-LX303
131.……………………..……….Purifi 1ET400A
104.……………………..……….Sony STR-ZA1100ES (Direct Mode)
67.……………………..…………NAD C 320BEE
50.……………………..…………Yamaha WXA-50
27.……………………..…………Denon PMA-50 (USB In)
pozz
Contributor
Patreon Donor
Editor
#6
pozz
Contributor
Patreon Donor
Editor
#7
pozz
Contributor
Patreon Donor
Editor
#8
pozz
Contributor
Patreon Donor
Editor
#9
Comparison of Headphone Amplifier Output Impedance Measurements
Number of Entries: 140
Date Updated: 26 August 2019
Links
0.3…………………………....……E1DA 9038S
0.4………………………....………Burson Play
0.5……………………....…………LH Labs Go2Pro
0.5…………………....……………RME ADI-2
0.6………………....………………AudioQuest Dragonfly Black
0.6……………....…………………Cavalli Liquid Carbon X
0.6…………....……………………Schiit Magni 3 (High Gain)
0.7………....………………………Benchmark DAC3 DX
0.7……....…………………………Chord Mojo
0.7…....……………………………Gustard A20H
0.7....………………………………JDS Labs Atom (High Gain)
0.7……………………………....…Schiit Fulla V1
0.7…………………………....……Speaka
0.8………………………....………Audeze Deckard (High Gain)
0.8……………………....…………Fiio Q1
0.8…………………....……………LH Labs Go2Pro Infinity
0.8………………....………………Cavalli Liquid Spark (Low Gain)
0.8……………....…………………Monoprice Monolith THX AAA DAC (Portable)
0.8…………....……………………Neurochrome HP-1 (Low Gain)
0.8………....………………………Schiit Jotunheim
0.9……....…………………………Apple Dongle
0.9…....……………………………Arcam rHead
0.9…………………....……………Benchmark HPA4
0.9………………....………………Emotiva DC-1
0.9……………....…………………KORG DS-DAC-100
0.9…………....……………………Cavalli Tube Hybrid
0.9………....………………………Meier Corda Jazz
0.9………………………………....SMSL iDEA
0.9………………………………....Spectra X
0.9……………………………....…Topping NX4 DSD
1.0………………………………....Fiio K5
1.0……………………………....…iBasso DX120
1.0……………………………....…iFi iDSD Black
1.0…………………………....…....iFi Nano iDSD Black
1.0………………………....………JDS Labs The Element
1.0……………………....…………Little Labs Monotor
1.0…………………....……………Massdrop THX AAA 789
1.0………………....………………Cavalli Liquid Platinum
1.0……………....…………………Okto Research DAC8
1.0…………....……………………Schiit Fulla V2
1.0…………………………....……Topping DX3Pro (High Gain)
1.0………………………....………Venture Electronics (Veclan) Odyssey HD
1.1……………………....…………Cyrus soundKey
1.1…………………....……………ENCORE mDSD
1.1………………....………………Gustard H20 (High Gain, Jack 2)
1.1……………....…………………Lake People G109-S (Medium Gain)
1.1…………....……………………Musiland MU1
1.1………………………....………SMSL AD18
1.1……………………....…………Topping MX3
1.1…………………....……………Yulong DA10 SE
1.2………………....………………Accuphase E-270
1.2……………....…………………AudioQuest Dragonfly Red
1.2…………....……………………Google Dongle V1
1.2………....………………………Grace Design m900
1.2……....…………………………Musiland MU2 Plus
1.2…....……………………………Rega Ear
1.3....………………………………JDS Labs O2 Amp (High Gain)
1.3…………………………....……JDS Labs Objective Rev B
1.3………………………....………Monoprice Monolith THX AAA DAC (Desktop)
1.4……………………....…………Melokin DA9.1
1.4…………………....……………Oppo HA-1 (Normal/Low Gain)
1.5………………....………………Fiio E10K Olympus 2
1.5……………....…………………Oppo HA-2SE
1.5…………....……………………Teac HA-501 (High Damping Factor)
1.6………....………………………Cambridge Audio Alva Duo
1.6……....…………………………Cypher Labs Theorem 720
1.6…………………………....……LG G7 ThinQ
1.6………………………....………Schiit Lyr
1.7……………………....…………Chord Hugo 2
1.8…………………....……………Fiio K3
1.8………………....………………FiiO Q1 Mk2
1.8……………....…………………Sabaj Da3
1.9…………....……………………CEntrance DACPort HD
1.9………....………………………Matrix Audio Element X (Low Gain)
1.9……....…………………………Pro-Ject Pre Box S2 Digital
1.9……………………………....…ZorLoo ZuperDAC-S
2.0…………………………....……Auralic Gemini 2000
2.1………………………....………Creative SoundBlasterX G6 (High Gain)
2.1……………………....…………FX-Audio DAC-X7 (3.5mm Headphone Out)
2.6……………..……..……………Schiit Lyr 2 (Low Gain)
2.7…………..……..………………Audio-gd NFB-27.38
3.0………..……..…………………Sabaj D5
3.1……………………………....…Ayre CODEX
3.1…………………………....……SMSL VMV VA2 (High Gain)
3.2………………………....………Samsung S8+
5.5……………………....…………Topping NX3s (High Gain/Battery Power)
5.6…………………....……………xDuoo TA-01
5.7………………....………………NuPrime uDSD
5.7……………..…………………..PS Audio Sprout100
5.8…………..…………………..…Schiit Valhalla 2 (Low Gain)
5.9……………………………....…Aune X1S
5.9…………………………..……..HTC Dongle
5.9………………………..……..…Mytek Stereo 192 DSD
6.2……………………..……..……Teac HA-501 (Low Damping Factor)
6.8…………………..……..………ENCORE mDAC
7.6………………..……..…………Google Dongle V2
8.2……………..……..……………FX-Audio DAC-X6
8.9…………..……..………………Audio-gd R2R-11
9.8………..……..…………………Topping DX7
10.0……………………………..…Asus STX II
10.5…………………………..……Topping DX7s
10.6………………………..………Audirect Beam
10.7……………………..…………Sony PHA-1
10.8…………………..……………Topping A30
11.0………………..………………Parasound Zdac V2
11.1……………..…………………Aune X7s
11.1…………..……………………Essence HDACC II-4K
11.1………..………………………FX-Audio DAC-X7 (6.5mm TRS)
11.2……..…………………………KORG Nu:Tekt NuTube HA-KIT
11.5…..……………………………Audioengine D3
11.5..………………………………Hifime Sabre 9018
11.9……………………………..…Klipsch PowerGate
14.9…………………………..……Schiit Valhalla 2 (High Gain)
15.0………………………..………Shozy Alien+
17.1……………………..…………HP Z-14
17.4…………………..……………Gustard H10 (Low Gain)
21.0…………………………..……Apogee Groove
21.7………………………..………LOXJIE d20
22.0……………………..…………Asus Xonar U7 Mk2
23.7…………………..……………SMSL M10
27.9………………..………………Topping A30
29.5……………..…………………Woo Audio WA7 & WA7tp (Low Z)
31.0……………………………..…HiFiMAN EF2A
33.8…………………………..……Cambridge DacMagic Plus
33.9………………………..………Teac HA-P50
35.1……………………..…………Loxjie D10
35.6…………………..……………Creative SoundBlaster X-FI HD
37.0………………..………………Totaldac d1-six
46.9……………..…………………xDuoo TA-10
51.0…………..……………………Gustard H20 (Jack 1)
54.1………..………………………Little Dot Mk3
57.3……..…………………………Teac AX-501
68.8…..……………………………Denon PMA-50
74.9……………………………..…Schiit Valhalla
78.0…………………………..……DarkVoice 336SE
79.8………………………..………Woo Audio WA7 & WA7tp (High Z)
95.3……………………..…………Marantz HD-AMP1
153.7………………………………SMSL VMV VA2 (Low Gain)
331.6………………………………Sony UDA-1
408.7………………………………Sony HAP-S1
pozz
Contributor
Patreon Donor
Editor
#10
pozz
Contributor
Patreon Donor
Editor
#11
pozz
Contributor
Patreon Donor
Editor
#12
pozz
Contributor
Patreon Donor
Editor
#13
Comparison of Headphone Amplifier Max Power (50Ω Balanced) Measurements
Number of Entries: 22
pozz
Contributor
Patreon Donor
Editor
#14
pozz
Contributor
Patreon Donor
Editor
#15
pozz
Contributor
Patreon Donor
Editor
#16
pozz
Contributor
Patreon Donor
Editor
#17
Comparison of Portable DAC/Headphone Amplifier Output Impedance Measurements
Number of Entries: 42
Date Updated: 23 August 2019
pozz
Contributor
Patreon Donor
Editor
#18
pozz
Contributor
Patreon Donor
Editor
#19
Comparison of Portable DAC/Headphone Amplifier Max Power (300Ω) Measurements
Number of Entries: 37
pozz
Contributor
Patreon Donor
Editor
#20
Comparison of Portable DAC/Headphone Amplifier Max Power (33Ω) Measurements
Number of Entries: 32
