I have DX7 pro and HD600 v2 with Mogami cable single ended. Before I had IFI nano LE so I compare a little bit what is important for me.
From technical side:
-more power then IFI but not so much
-volume knob, lots of steps with cliking and push to power on. IFI in this case is better, smooth with power on by rotating with click
-selectable gain h/l in plus
-with spotify sampling up to 48khz, with higher spotify show error
-digital filter makes no difference
-volume adjustment very precise from the begining, ifi on low level was crazy
-replaceable op amp
Sound(with HD600) vs IFI nano LE:
very detailed, very bright, generally whole sound shifted to lightnes, with deformed vocal and not energetic bas. Scene much bigger. In lots of cases ifi was better with more musical and smooth sound but in some cases was also devasteted. DX7PRO has very good sound control without anomalies expect very very high but with bright schemme on all range. Generally very specific, detailed, separated, cold, not natural, with small mess on high sopran. Quality not relate to price with HD600, there is feel of potential but thats all. Darker HD650 will be better for sure. I was close to send back but I tried to roll op amp.
I repalced 2xLME 49720 to 2xOPA1612 on LPF and... my ass has fallen off on the floor. Complete shift, energy and expresion comes back, brightnes was compensated, sound becomes 'big', scene about the same, with vocal just before face like in IFI but more detail. It is still bright but in positive meaning. I removed ifi from desk and foil from display. Only whats left is small mess on very high sopran. LME 49720 is wild. I tried also OPA1612 on amp section and effect was simillar but not the same, mess on very high sopran stays anyway. Next step could be replacing leftover LME by LME 49880 then we will see...
Genererally impressive sound but not directly from box (at least with HD600)
Other thing are generally positive opinions on reviews of dx7 PRO. Not everybody replace op amps. I can't belive that only HD600 has problem with this amp. Many headphones are the same or brighter then HD600. Maybe HD600 are specific, maybe balanced output is better, I didn't check, or maybe I'm half deaf or somone else is half deaf or has bussines in writing review
