The documentation says "Output impedance: <0.1Ω ", which seems like a great match for low impedance headphones based on the 1/8th rule. However, the review says "the amp doesn't like very low impedances" and references clipping/protection. I'm new to these technical details, so forgive my ignorance.
Based on the 1.5 watt max power at 32Ω, is it accurate to say that problems only occur at the highest gain levels, or is there a more general impedance mismatch that could affect performance even at reasonable volumes?
For context, I have Sennheiser HD650 (which should be fine) and HiFiMan HE400i 2020 (35Ω, 93 dB/mW). I'm looking to upgrade from an iFi Nano Black Label (285mW/30Ω). I generally listen at conservative volume (knob at 12:00-1:00 for the 400i on the iFi). However, I've started using PEQ with Roon and would like additional headroom - especially for the HD650. But I want to make sure the DX3 Pro+ would also be a good match for the HE400i planars.
