Best DAC/AMP under $300 for Neutral Headphones
Loginov
Hi everyone!
I’m a newbie with no real experience in audio gear. My headphone amp just died, and now I’m not sure what to do next - so I’m looking for some advice on choosing a new DAC/AMP.
I currently use Sennheiser HD 560S, occasionally listen on Audeze MM-100, and I’m planning to buy Sennheiser HD 600 or HD 490 PRO in the future.
I’d like to get a device around $300 (if possible) that can drive these headphones properly in terms of both power and sound quality.
I’m especially looking for neutral and detailed sound, but I also want listening to be pleasant and engaging - not fatiguing.
I'm curious about balanced output, mostly for future-proofing, but I don't have much experience with it yet.
Display, MQA, Bluetooth, or whether it's a combo or separates - not important.
One idea I'm considering:
Since I plan to use neutral or analytical headphones, I thought that pairing them with something slightly warmer and smoother like the iFi Audio Zen DAC 3 might create a good balance - a kind of synergy between detail and musicality. Would love to hear thoughts on that.
One complication: Schiit and JDS products are difficult to get or support in my region, so I'm a bit hesitant to go that route.
Does anyone here have experience with these headphones or similar setups?
What DAC/AMP options would you recommend? And with this budget, is it realistic to meet my goals?
So far I’m looking at:
SMSL C200 Pro, FiiO K7, Topping DX3 Pro+, iFi Audio Zen DAC 3, and similar models.
Thanks in advance for any help!
Currently using Senn HD560S with the SMSL RAW MDA1 and really enjoying the experience. I'm no audio expert so can't give you a detailed response about the technical elements, but it comes recommended by me.
Note, there's probably several posts on here and other places referring to "clicks and pops" when tracks and/or bitrate changes - this is present on my unit, but it's not something that bothers me a lot, but might be worth reading into before going ahead with anything.
Someone else asked a similar question recently here >> https://audiosciencereview.com/foru...other-help-me-pick-a-dac-headphone-amp.63775/
Good luck with the search!
thanks!
Hi and welcome to ASR!
Personally, I don't think that's the best approach. Instead of chasing "synergy" through colored gear - which might sound great with one pair of headphones but poorly matched with another - I think it's more practical to invest in a truly neutral, transparent DAC and amp. That gives you a consistent baseline for a wide range of headphones.
Relying on gear coloration limits flexibility. Are you going to swap DACs or amps every time you switch headphones? Instead, get into EQ. With EQ, you can take a bright headphone and shape it into something warmer - on your own terms. There are threads here on EQ and measurement databases that make this easy and effective.
In the long run, a clean signal chain and EQ will serve you much better than trying to find "magic" pairings.
For example all the headphones you mentioned will benefit form EQ - Oratory1990 database:
Search the forum for DAC/amp measurements and see what Amir recommends - there are lots to choose from.
Example:
Topping E30II + L30II 330 eur
Topping E50 DAC + L50 - balanced - 400 eur
Topping E70 + L70 - balanced - very powerful - 617 eur
Btr17 excellent sound but is portable.
You may not even need a separate DAC or headphone amp if whatever is built-into your phone, computer, stereo, etc., goes loud enough...
There is no inherent advantage to a balanced headphone connection and you can always use an adapter to run balanced headphones from a regular headphone output.
You CAN get double the voltage (6dB louder) from a balanced output stage "all else being equal". But there are easier ways of getting double (or more) voltage if you need it.
IMO it's a useless gimmick.
...Balanced line level (and microphone) connections provide more noise immunity but you can't pick-up enough electromagnetic noise energy to drive a headphone (or speaker). Balanced line level connections are generally unnecessary "at home" unless you have ground-loop noise or something and it's just not common on home audio equipment. Stage & studio mics use balanced XLR connections, as do most line-level connections in recording studios and pro PA setups.
Topping just released the DX5 II. There is a lot of value in that option. Check it out.
