I blame the alphabet and the Language barrier. They couldn’t read the 40s-50s schematics at the timeMaybe if Topping put resistors in series with the line driver ouputs like proper manufacturers, they wouldn't have to post warnings about shorting using a TS 1/4".
Or spend some dollars and put a few relays in line along with a short circuit detection circuit.
Maybe my post wasn't clear enough. I meant that 'balanced only' was cheaper compared to 'balanced + unbalanced'. 8 connectors instead of 16, hence a bit cheaper.Nope. Unbalanced would have been cheaper but at the expense of some specs.
Oh,ok,you mean (-) unconnected so it doesn't short,got it.That has nothing to do with what I said. I’m talking about circuit you are referring to the connector. Obviously a balanced TRS connector should be inserted to the Topping DAC’s output. That’s a given. However, you can wire that balanced connector output to feed an unbalanced input. This is not rocket science and it’s been done since the 50s. Sleve to sleeve, tip to tip and ring left unconnected.
My full range center channel sits in storage, and I don't miss it. I simply mix the center into the mains for multichannel music. I don't care about movies. Movies isn't my thing.I know. And what happens when you connect it to an unbalanced equipment using any type of balanced > unbalanced cable or adapter? I'm curious.
Not for stereo music of course: for movies, and more generally for any kind of multichannel audio requiring a center channel.
Good luck mixing this preamp, Atmos and video together.I just ordered one of these. Is there anyone in this thread who has successfully replaced their home theater preamp with one of these? I went back several pages and found many people who have future plans of building a system like this, but not yet many success stories. Especially when it comes to decoding TrueHD/Atmos/DTS.
There seems to be a few software options now, from jriver to the Dolby Reference Player and other hacky solutions to decode into individual PCM tracks that this DAC can decode into balanced analog. Anyone have success with this? I can do the preamp volume control later down the line after decode, at the dsp level.
That was my quest and it failed horribly.I just ordered one of these. Is there anyone in this thread who has successfully replaced their home theater preamp with one of these? I went back several pages and found many people who have future plans of building a system like this, but not yet many success stories. Especially when it comes to decoding TrueHD/Atmos/DTS.
If someone does figure this out please post here. I wasn’t satisfied with mixing down the center channel. I was using the voicemeeter 8x8 matrix app. Just didnt sound as good as my AVR.Good luck mixing this preamp, Atmos and video together.
For 5.1/7.1 I usually use my Oppo (HDMI INPUT) to downmix, although jRiver and Foobar using DSP works well. For Atmos, I decode the Atmos, then use Audacity to downmix the file, and output as 4.0.4 FLAC.I wasn’t satisfied with mixing down the center channel. I was using the voicemeeter 8x8 matrix app. Just didnt sound as good as my AVR.
Not perfectly.The reason I ask is I found a excellent multi-channel tube pre I am considering getting and this DAC would work perfect with this Tube Pre (Decware)
How do you decode the atmos?For 5.1/7.1 I usually use my Oppo (HDMI INPUT) to downmix, although jRiver and Foobar using DSP works well. For Atmos, I decode the Atmos, then use Audacity to downmix the file, and output as 4.0.4 FLAC.
MMH+DRPHow do you decode the atmos?
This has only worked for me for audio. I can take an MKV, use MMH to extract the atmos, and then play it back in DRP. But then the video is gone. How can i sync it back up with video?MMH+DRP
Sorry. I am just into Atmos music. I haven't tried muxing audio and video.This has only worked for me for audio. I can take an MKV, use MMH to extract the atmos, and then play it back in DRP. But then the video is gone. How can i sync it back up with video?
I guess there is no way to play back MKV directly?
What noise?Not perfectly.
1. The DM7 has only balanced outputs and the Decware has only unbalanced inputs.
2. Why would you sully the clean outputs of the DAC with a noisy tube preamp?
"I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, I want a pony, What I don't want to do is carefully read the specs and the many threads in the forums related to this unique piece of kit" We will no doubt be reading many "pony" requests for an infinite number of turns around the sun.I can't believe we are doing this again.
Well, it's self-reported SNR is significantly higher than the Topping. More significantly, I see these two products as antithetical.What noise?
If you are fond of tubes, then you might as well get a tube DAC. Together, those two greatI found a excellent multi-channel tube pre I am considering getting and this DAC would work perfect with this Tube Pre (Decware)
