I can report that multichannel MKV, DSF, Flac, WAV and DFF files will play from an android Samsung tablet, using varied applications (VLC and Foobar 2k). I truly love the DM7. Except for some really ridiculously crazy "thick" PCM and DSD\DFF files (above DSD128 or PCM 192), it handles everything.I'll have to repost my question. I saw in the thread that multichannel WAVs play back perfectly via android to the DM7. Did anyone try to do internal decoding of dolby/dts with the shield and output it over USB to a DM7?
I don't own this particular device, but I do manipulate channel layouts, and in Windows, Foobar2000 is the only app I have working with multiple devices and setups. Just add the Matrix Mixer component and WASAPI component. JRiver works too, but I switched devices and couldn't figure out the mapping. It will probably work but I gave up on it and just use Foobar when I need to map decoded Atmos PCM files.Reviving the thread because I found a DM7 to try out and wanted to briefly return to the question of channel mapping on the Topping when the number of channels isn’t 5.1. I plan to use EQAPO at first.
Does anyone have any experience with this? I don’t have a center channel and don’t plan on getting one anytime soon, but I have two subs. This means that I’d either use L/R in Stereo with two subs (2.2) for music or L/R + rears with two subs (4.2) for movies. I guess my question is banal, but - how well does this constellation work?
I’ll find out myself soon enough in any case and will report back with my experience
Sorry for the late response - been busy lately. I did in fact manage to set everything up as outlined in the post above. For the time being, until I find a proper center speaker, I have a 4.2 system that can reproduce multichannel content. Navigating channel mapping, which never ended up working in peace and had to be done in stock apo (to which, like peace, I developed a love-hate relationship), windows audio driver bs, output to REW, and various other little things that just aren’t quite perfectly intuitive coming from, say, a minidsp platform, was, however, a pain in the ass. At times I got frustrated and went looking for a real (encompassing all possible functions) alternative to EQAPO and wouldn’t you know it there isn’t one. But yeah, it all works, if you accept a slightly less user friendly experience, you can do (almost) anything you want with it. And I strongly advise everyone using EQAPO to also install peace, bc eqapo is almost unusable without it in complex configurationsdid you get a chance to try it yet?
Peace is a dumbed down version of the stock EQApo configurator.I might try peace
It adds some features like clipping detection and AutoEQ database for quick preset loading, but it's much less configurable and IIRC is limited to PEQ only.
It’s just a visual interface for EQAPO. With it there is just way less visual clutter, especially if you run more than two channels. I use it for EQ, HP/LP filters and delays - the stock configurator can still be used with peace activated. I can’t imagine running my config without peace, it’d be a mess to look at/work with.Peace is a dumbed down version of the stock EQApo configurator.
Focusrite Scarlett 4i4 4th GenAny recommendations for an inexpensive, transparent 4 or 8-channel DAC, now that the DM7 is discontinued?
Thanks! Seen any measurements of DAC performance?Focusrite Scarlett 4i4 4th Gen
Please check this out:Thanks! Seen any measurements of DAC performance?
SINAD = 115dBPlease check this out:
