jmz
I ordered two... the price was great. One for work and second for home.I just ordered one on Aliexpress. Are there firmware updates it will need?
Thank you for the answer. What is the source of this information?The D50III supports USB 2.0 Hi-Speed (480Mbps) at the most, but will likely still function at USB 1.1 Full-Speed (12Mbps).
It's not about USB speed, it's about UAC driver version these consoles use.You can actually change the usb speed setting in the menus. This is great as d50 iii can be connected via usb to game consoles that only use the old usb speed.
That's correct, for the life of me could not remember the acronym.It's not about USB speed, it's about UAC driver version these consoles use.
I've got neutrik TRS on mine with mogami w2534 microphone cable to XLR connectors (powered monitors so cables fine, amp would probably melt them)What are people using for TRS cables in the back?
Great cable for pc users with powered speakersMogami Neglex quad cable is perfect cable for home studios suffering from wiring and grounding problems. Mogami 2534 should also be used where intense RFI interference is a problem. Mogami 2534 provides an improvement in signal to noise of 10-20db over equivalent twisted pair cables. Double conductors quad cables are more effective in canceling noise that can get past even the best of shields and is critical in an environment of high RF and EM interference.
I was asking about TRS cables to connect the DAC to the amp in a stack. I saw Topping had a pair of short TRS cables just for this, but it doesn't seem to bend well when the DAC and amp are stacked right on top of each other.I've got neutrik TRS on mine with mogami w2534 microphone cable to XLR connectors (powered monitors so cables fine, amp would probably melt them)
www.audiosciencereview.com
Use a USB 2.0 480 Mbps Isolator between the PC and the DAC.It's starting get cold and dry where I'm at, so there's a lot more static build up, especially when my chair moves around on my carpet. Pretty sure my PC is grounded well enough as I never shock myself with any of the components. My issue is with the SMSL RAW-MDA1. I have two other DAC/amps that I never had this issue so that's why I'm guessing the SMSL just isn't as good with dealing with static electricity.
I'm clueless about electrical engineering, but since my other two DAC/amps have an external power brick and the SMSL has a direct power cable, I'm suspecting that design is making it more susceptible to static since the parts converting AC to DC is sharing the same PCB as everything else. I'm sure it can be built well to avoid this, but an average consumer like me would have no way of knowing staring at the PCB design. Since the Topping D50 III doesn't do that, I'm just wildly guessing that I won't have the same issue with this.
I just placed my order for the D50 III/A50 III, P50, JDS cables, and HS02 USB Isolator. Good thing I had so many Amazon gift cards that I've been saving.Use a USB 2.0 480 Mbps Isolator between the PC and the DAC.
yea I wouldn't know about that.I was asking about TRS cables to connect the DAC to the amp in a stack
The ideal Nyquist filter has 0dB attenuation at sample rate / 2 and full attenuation at 1 + sample rate / 2.Mainly just trying to understand what is the ideal line when reading the graph I'm referring to
Is that 1 + (sample rate/2), so ideal full attenuation for 44 kHz would be at 23 kHz?The ideal Nyquist filter has 0dB attenuation at sample rate / 2 and full attenuation at 1 + sample rate / 2.
Full attenuation means losing imaging? As in sense of distance in the sound? I'll just have to try it out to see if I can hear the differences whenever these cables come in. What would be the best way to see the differences? Tracks with high pitched instruments like the violin, or tracks that have a lot of positioning such as 8D tracks.Do you value HF extension more, or clean playback without imaging.
Ideally, full attenuation just above the Nyquist frequency, so at 22051Hz.Is that 1 + (sample rate/2), so ideal full attenuation for 44 kHz would be at 23 kHz?
No, imaging as in the phenomenon of passband content being mirrored above Nyquist, as a result of leaky reconstruction filters.Full attenuation means losing imaging? As in sense of distance in the sound?
Yep, especially at higher sample rates (48kHz+). The only slightly audible difference is at 44.1kHz SR.I've seen a good amount of people claiming they don't hear any differences between them.
