Pulkass
- Joined
- Feb 17, 2019
- Messages
- 276
- Likes
- 60
I'm going to be as nice as possible but...Can t play dsd files, or better, it plays them, but at 44khz. And the device capability reaches only 96 khz. Installed topping 5.30 (newer) driver !!!! Dac topping d30 pro.
Thanks. I thought it was easier. Even Topping states that Asio installing is very complicated, infact they suggest to just connect the DAac aI'm going to be as nice as possible but...
Please don't expect other people to just guess what the problem might be, if there is one in the first place, before you did your own research and problem solving.
You can (re)install different Topping drivers all day long but I can tell you now that this is almost certainly not where the problem lies.
That you post a screenshot of the Windows sound properties window also tell me that you don't really know and/or understand what or where the problem might be with DSD playback on your system. As again the problem is almost certainly not going to be solved in the Windows sound properties window.
So please do you own research first. Look up and follow some guides on how to set it up, follow instructions as included in the driver package for example. Then if it still doesn't work explain to us which steps you have followed and all relevant settings. That way other people will be to help you much better. This will work much better then you just posting "It doesn't work!!!!!"
I'm not going to post possible solutions as you have pretty much give nothing to go on so it will be just a random shot in the dark. Guessing by the irrelevant screenshots right now you don't fully know and/or understand how it should work where the issue(s) might be.
I will give you one big tip though; 95% of the magic sauce to get this to work can be found in the playback module(s) and/or settings of your media-player of choice.
Yes , FOOBAR has been set up correctly via Any Desk, it can play DSD files, lots of plug ins though , the Topping driver
no.Is there significant sound difference between both unit?
Does spending more on d30 pro gives any large sound difference or what.
No. Features, convenience, and matching style.Hello
I'm new to this thread
I have a30 pro and hifiman arya
Confused which one to buy,D10 balanced or D30 pro for normal laptop musicbee player.
I’m quite amazed you can listen to it at a volume where the protection kicks in.What about dc in audio?
When i play recordings having DC source the a30 pro shut off and on at peak volume with my dc powered fiio k3 usb dac.
Will a30 pro goes to DC protection when paired with D10 balanced same as my fiio k3 since d10 balanced also dc powered.?
Hmmm. This is the one I thought I wanted … for tv and DVD/CD player I intended to use toslink.Bought the D30 pro twice, great sound but limited DSD playing capabilities, and not playing CD out coax or optical. I sent back both.
Optical out of cd player had problems . Sent back.Hmmm. This is the one I thought I wanted … for tv and DVD/CD player I intended to use toslink.
Glad you enjoy it. It's just a very good DAC noAlso... The Coax in sounds terrific.
Can you include a link of the upsampling interface with a decent buffering that you use so people can get an ideal of the specs?Hi there, I've solved the "SPDIF In" thing. Now every CD transport I own works fine. Placing an upsampling interface (with a decent buffering) between CD's SPDIF out and Topping's SPDIF in wipes dropouts off.
