Heads up, there is a new firmware for the D30 Pro available
https://www.tpdz.net/newsinfo/491852.html
Also I just installed the driver from the website. I hadnt bothered since it was working fine without it (at least with PCM output)
It required me to 1) run the executable driver installer 2) restart 3) run the executable again *then* it worked. It wasnt clear that I had to run it twice but that's what I needed to do.
Scary scenario!
I take back what I said earlier about OS controlled volume. After I installed the drivers, the volume control method changed. OS volume now has no effect.
OK I'm sort of new to DSD but I installed drivers and downloaded a track that uses DSD and I was able to get DSD to work in both PRE and DAC modes. In both modes I am unable to control volume via Roon or via OS. The knob on the device works only in PRE mode. And so I see no reason not to have it in PRE mode.
OK... Dangit I was supposed to be asleep an hour ago.
