Was there some other firmware for this device? I ask because on archimago blog he mentions a (running linear phase sharp filter firmware).
There is no firmware update for the D10s yet.Was there some other firmware for this device? I ask because on archimago blog he mentions a (running linear phase sharp filter firmware).
Not sure the review is here was actually surprised that the Topping HS01 did workThere is no firmware update for the D10s yet.
Isn't the blog just stating personal wishes for the D10s?
The firmware he's talking about here is the firmware the product comes with by default. It is not about newly updated firmware.Not sure the review is here was actually surprised that the Topping HS01 did work
MEASUREMENTS: Topping HS01 - USB 2.0 Isolator & Ground Loop Eliminator (and a listen to Santana's "Blessings and Miracles")
A blog for audiophiles about more objective topics. Measurements of audio gear. Reasonable, realistic, no snakeoil assessment of sound, and equipment.archimago.blogspot.com
Yes.Since this does not have the pre-amp like the E30 II, can you still control the volume via the PC/Windows then?
…and this can be done ( might be ) in a better way in the computer , adding dithering and such.Yes.
Although possible, this is not recommended. Knowing that the output is nominal 2 Volt, when sliding the volume up, you get full power. And when set at low volume, it might be very difficult to get the volume right. You will also get a worse S/N as all computernoise will go through at 100% and the signal at a much lower percentage. Know that the USB input of this DAC is not filtered as good as all other Topping DACS. You probably would be very disappointed.Since this does not have the pre-amp like the E30 II, can you still control the volume via the PC/Windows then?
I dont see any fact pointing at this .Although possible, this is not recommended. Knowing that the output is nominal 2 Volt, when sliding the volume up, you get full power. And when set at low volume, it might be very difficult to get the volume right. You will also get a worse S/N as all computernoise will go through at 100% and the signal at a much lower percentage. Know that the USB input of this DAC is not filtered as good as all other Topping DACS. You probably would be very disappointed.
Actually, I owned this DAC (for a few days - sent it back).I dont see any fact pointing at this .
We are talking digital signals here.
And can be resolved with a topping hs01 or similarThat's a ground-related noise issue, not non-perfect USB ports. It's a risk on any USB dac with single ended outputs and no galvanic isolation.
The same could be said about most USB DACs. They work well enough for most people most of the time, but have consistent problems for some people some of the time that aren't really caused by the DAC as such, but the system as a whole. More often than not the pops end up being an issue with the combination of hardware and drivers on the computer in question, although it is sometimes down to the DAC itself.I have one of these and have not had any issues with desktop or laptop. I do see a good many other comments about it as well as pops and other things from other owners.
The bolded part above is a false statement if you are specifically referring to this DAC. While it is a true statement that any DAC can get CPU/USB noise, it's really dependant on the computer, it's own level of USB noise, and every other thing connected to the USB chain. As an example, the following DACs all emit very audible CPU noise when my Mac laptop is connected to my desktop system:Actually, I owned this DAC (for a few days - sent it back).
I could hear my computer through it. (eg CPU-noise, mouse movement - something described elsewhere on ASR) That was with a Desktop PC. No problem with a portable.
Other Topping DAC's connected to that Desktop PC did not suffer from it. So there is a difference in the implementation of the USB connection, adding or letting through too much input noise.
So what I mean : if you happen to have a non-perfect USB port on your computer, chances are you will "hear your computer" with this DAC. And when using digital volume control on the PC means the "sound of the computer" will be at 100% over lower signal. Hence, not a good idea.
Is there any difference in USB noise íf you disconnect your Mac laptop from the mains, running it on batteries instead ?The bolded part above is a false statement if you are specifically referring to this DAC. While it is a true statement that any DAC can get CPU/USB noise, it's really dependant on the computer, it's own level of USB noise, and every other thing connected to the USB chain. As an example, the following DACs all emit very audible CPU noise when my Mac laptop is connected to my desktop system:
To get around this, I've used the D10s as a USB > Optical bridge to decouple the signal. That is, until I got the miniDSP Flex. The miniDSP Flex is the only DAC that I've ever connected to my Mac that did not make audible USB noise. So my experience is the exact opposite of yours. This is to say, it's the specific combination of your computer and the crap you have, and not the fault of any specific DAC.
- Schiit Modi +
- Topping D10s
- Topping E30
- a cheap off brand DAC who's name I forget
Unfortunately I don't recall all the permutations of the testing that I did 11 months ago.Is there any difference in USB noise íf you disconnect your Mac laptop from the mains, running it on batteries instead ?
