Perfect for my desktop system-PC > D10B > XLR > THX 789. Since my D70 is now in my main system.Amazing value although destined for use in relatively sparse systems. There is no RCA out for subs and of course only USB in. Thank you @amirm .
No matter how I will not recommend it. All the needed information is published in the spec. I did my part. After that you have to be on your own.Is there something about the output circuitry in the D10B that would make Balanced TRS-to-Unbalanced RCA cables—pictured below—cause a failure in the D10B?
From Rane Application Note AN110, Sound System Interconnection. Output from D10B on Left. Input to other device on Right.
Other than the signal level drop, increased SINAD, and possible ground loop issues caused by going from balanced to unbalanced, this has been standard practice for decades.
If you haven't seen this, it is noted the D10 balanced does not support any adapter to single ended.Is there something about the output circuitry in the D10B that would make Balanced TRS-to-Unbalanced RCA cables—pictured below—cause a failure in the D10B?
Transformer is for the coax output. The dac circuit is just normal balanced implementation.Please give me advice.
As for the balanced output method, the information I got from the article of L7 Audiolab initially said that the transformer output was adopted. Is it actually a transformer method? Or is it a method using a general OP amplifier?
https://www.audiosciencereview.com/...d10-balanced-review-usb-dac.25094/post-853225Useless connection, only USB in, who needs Spdif OUT from a DAC?
The D10 series is a model that combines a USB-DAC with a DDC (Digtal To Digital Converter). If you don't understand this, the D10 series will look like a pointless product. Never look at it in the same way as a typical DAC.Useless connection, only USB in, who needs Spdif OUT from a DAC?
Just go for the D10s if you don't have any intention of using balanced.Is there something about the output circuitry in the D10B that would make Balanced TRS-to-Unbalanced RCA cables—pictured below—cause a failure in the D10B?
@JohnYang1997 , I take it that the D10s will still be maintained and sold alongside the D10b ?Just go for the D10s if you don't have any intention of using balanced.
Why purchase the balanced version when you're not going to use balanced?
The D10s is still by all means a good performing little DAC, not like it's going to be an audible issue or anything.
That's correct.@JohnYang1997 , I take it that the D10s will still be maintained and sold alongside the D10b ?
Me too.ordered one
Great little USB only D/A converter, but totally silly idea to have SPDIF/Toslink out instead of in. Just makes no sense. Think of all the millions of people wanting to upgrade a CD/DVD/TV sound etc.
Allow me to frame the question differently.
What purpose is there to have optical and coaxial SPDIF on this DAC at all? I see wasted real estate.
There is the E30 for this? Silly maybe but there are hundreds of the Dac you describe, way enough to chose from for those millions of people, they are well tought about I don't worry for them. There are however receivers out there, and dsp units, with spdif in and no USB, If this is your need options are much more sparse if you need to connect a computer digitally.Great little USB only D/A converter, but totally silly idea to have SPDIF/Toslink out instead of in. Just makes no sense. Think of all the millions of people wanting to upgrade a CD/DVD/TV sound etc.
I wouldn't consider Aeon "seriously hard to drive" unless you want to EQ +20dB in the lower ranges or something.- Headphone amp needs balanced in because of seriously hard to drive headphones
Yes, I noticed it right away. That's very strange.
Any recent and decent HP AMP can drive these fine over SE.
Me for example. I have headphones amp connected to D10 RCA, and distant integrated speaker amp to the SPDIF.Useless connection, only USB in, who needs Spdif OUT from a DAC?
Hidizs S9 is a portable dongle. As far as I can see it doesn't provide an actual line-out to properly feed the SH-9.Sorry, but my SH-9 is not sufficient if driven SE from the Hidizs S9 - and I'd call both recent and decent. No relevant EQ band is more than 5 dB, preamp is -3.5dB.
With a raised volume (not skull vibrating as Amir likes to say, but bearable only for a single track or so) it runs almost full throttle. I would like to have some headroom left.
